![]() | Home > Puma (Tdci) > Sump problem! |
red Defender Member Since: 11 Feb 2008 Location: Cornwall Posts: 76 ![]() ![]() ![]() |
Ill have another look
NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972 ![]() ![]() |
![]() ![]() ![]() Nice. ![]() Ok, added the list of things to check tonight in preparation for Salisbury. And for check afterwards too. Just realised I've not got around to ordering diff guards for the 'fender ![]() Ah well, it's Mrs Do$h's car, not mine ![]() I'm guessing the chances of pranging a diff casing in the mud and flint of Salisbury plain is pretty slim unless I stray onto a live range ![]() ![]() 54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
Spoke to the dealership today and asked what a new sump would cost. Expected something rediculous and so it was, �39 or so, the whole job including labour can be done for about �110.00, so its booked in for next Thursday, no more doubts about dumping all the oil.
About the dif guard, on a technical point, I was told that the guard is not to stop the diff being broken it is to stop compression of the casing causing the moving parts to rub on the inside and creating a nice iron filing paste to increase wear. ![]() |
110 back on the drive with new shiny and black sump.
Going to 'The Ultimate' at Easter to do some marshalling and will give the the 110 a work out before Morocco in April. Hope it dosent break again. ![]() |
Scallops Member Since: 15 Aug 2007 Location: Brisbane Australia Posts: 89 ![]() ![]() |
I too took the tech bulletin into my dealer here in Brisbane, Australia - they eventually agreed to change the sump pan even though it didn't have witness marks. For any Australian readers here - if your dealer is reluctant to change the sump pan - ask them to contact LR technical and explain that you are planning some remote hard core driving - they fix it then! Cheaper than a 2000 odd km recovery. ![]() |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
Mines booked ii to be done,, will let you all know, if i recive a bill !!!
![]() Main Brian James Trailer Dealer for South West UK |
Had the invoice for the new sump, �123.83 inc vat. Money well spent, I thought, until I read in LRO that the problem is only applicable to left hand drive models. Still its done now and not something to woory about. Have just returned from a 1000 mile round trip to The Ultimate and a good amount of off road work, and the old girl got me home with no real problems. ABS and TC lights stayed on a couple of times, but turn ignition off and back on and they cleared.
It's more prevalent in LHD models - but there has been at least one case of a RHD vehicle holing the sump too (from the cross axle issue). ![]() |
Is there any difference in the drive train between a left or right hooker
Got a call today, to say not to bother bringing in the 110 tomorrow for the later modded sump pan,, as they are all on back order !!
Mines now done,,
![]() Click image to enlarge I did ask for a new filter, so i paid that !! fair game Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Main Brian James Trailer Dealer for South West UK |
Softail Member Since: 18 May 2007 Location: East Lothian Posts: 42 ![]() ![]() |
Had the sump changed a few weeks ago on the back of this very helpful posting. My driveway's been oily ever since
![]() The leak is dripping from the rear of the sump area. I've checked the engine oil level on the last two occasions, and it seems to be very full - - above the max level on the dip stick. So; question - - - is it possible the dealership is just incompetent it properly fitting an oil tight sump / gasket. OR, is there something else going on (is the oil capacity the same with the new sump / if they're over filling with oil, will it cause a problem?) Apologies for the basic nature of the question. I'm not that technical ![]() ![]() Any thought's on this would be very welcome. Cheers |
rick Member Since: 07 Mar 2008 Location: Perth Posts: 133 ![]() ![]() ![]() |
Softail - do you have any idea what triggered the sump problem in the first place (eg off-roading) or was it a random event?
Cheers, Rick. 1998 RR HSE 2007 RRS TDV6 2008 Defender 110 2015 Discovery Sport |
Hi Rick, in essence, there wasn't really a problem to start with! The dealership changed the sump as per the technical bulleting above on this thread. They agreed to do this as part of the deal in me purchasing a 6 month old vehicle. So the experience of the oil leak has only been since the sump change.
The reason for my question below, is that I'm finding it hard to believe a dealership can find it so difficult to change a sump, and achieve an oil tight outcome! Thoughts anyone? |
