![]() | Home > Maintenance & Modifications > atric remap and codes |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2685 ![]() ![]() ![]() |
You get that every now and then, nothing to worry about. BTW, you can look up these error codes in the workshop manual (http://www.mediafire.com/?6vfad0z0bzso7) P023400 Turbocharger A over boost condition Turbocharger circuit fault Turbocharger fault Engine control module (ECM) fault Check the turbocharger and circuits. Refer to the electrical guides. Rectify as necessary. Check turbocharger operation, check for sticking turbocharger vanes etc.. Install a new turbocharger if necessary. REFER to: Turbocharger (303-04B Fuel Charging and Controls - Turbocharger - 2.4L Duratorq-TDCi HPCR (103kW/140PS) - Puma, Removal and Installation). Clear the DTCs and test for normal operation. Refer to the warranty policy and procedures manual if a module is suspect. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
If you want a quick look up while on the move for the code you can enter the P code in the search box of my web site for the text meaning.
http://bellautoservices.co.uk/bas-remap-interface/ Pete |
Tim seymour Member Since: 17 Jan 2010 Location: Devonport TAS Posts: 92 ![]() ![]() |
Cess the Taswegian |
thanks Pete cleared the codes only the po606 came back once againthanka to all ![]() |
