Home > Technical > Electric window
Page 2 of 5 <12345>
I'm still betting on it being a single switch problem Whistle ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #157033 20th Jul 2012 6:53pm
spudfan
Ireland
Could be as simple as a dodgy contact or a loose connection.Mine went on the driver's window and it was a broken wire in the rubber covering sleeve that goes from the door frame to the pillar where the hinges are. The wire used is very frail. You can pull the sleeve gently out from the pillar at the bulk head and open it up to check the wires. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #157038 20th Jul 2012 7:05pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Thanks Guys will have a look at the wires and try Swapping the switches over...thanks for all the help Bow down
will let you know Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #157049 20th Jul 2012 7:45pm
ZeDefender
K9F wrote:
ZeDefender wrote:
Why would a 5 Amp fuse feed to 20 Amp ones?
Trying to keep it simple. Supply relay fuse...same set up you should have if you fit auxilliary lights. Thumbs Up
Ignition supplies relay 5 amp fuse, pulls in relay, contacts of relay supply through 20 amp fuses window motors. Thumbs Up
In this case 3 amp feeds 20/25 amp...
Sorry - missed your reply.
Thanks, all is clear now Thumbs Up Tell someone you love them today because life is short.
Post #157051 20th Jul 2012 7:48pm
You will probably be able to remove the switches easily with out taking the dash out only the radio and access from the side only. This will be much easier for you then. Thumbs Up ____\We|Will|Win/___
Post #157052 20th Jul 2012 7:49pm
fekete
Thanks custom90steve, that's my job for Sunday then Rolling Eyes NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #157057 20th Jul 2012 8:01pm
Good luck Thumbs Up ____\We|Will|Win/___
Post #157058 20th Jul 2012 8:03pm
Trossachs turbo
Scotland 2005 Defender 90 Td5 CSW Oslo Blue
Same happened to me,it was a broken feed wire (red) within the flexible conduit between the doorpost and door.it is a well known fault, the cables get stretched and fail.slit open the flexi conduit, and resealing with self amalg tape
Post #157234 21st Jul 2012 9:46pm
fekete
Cheers Trossachs turbo, will check that 2moz when i have a play Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #157237 21st Jul 2012 9:58pm
fekete
Big Cry Big Cry Swap the switches over nothing check all the wires...removed the door card can't see anything wrong will have to get some one with a bit more knowledge than myself...thanks for all the help guys Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #157310 22nd Jul 2012 5:47pm
landy andy
Have you had a good pull at the wires between a post and door? If they are broken, which is very common, only the copper wire will be broken, not the insulation covering them.
Andy
Post #157316 22nd Jul 2012 6:34pm
fekete
I had a good look will try again but they all seemed ok Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #157317 22nd Jul 2012 6:37pm
Have you checked with a multimeter that there is power there? ____\We|Will|Win/___
Post #157346 22nd Jul 2012 8:43pm
fekete
No mate don't have one will get one of the lads to have a look....I'm not very good with wires Embarassed NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #157348 22nd Jul 2012 8:50pm
Ah right, If I was local you could have borrowed mine or I'd check it for you but not possible. I am wondering if perhaps it is a short now... ____\We|Will|Win/___
Post #157351 22nd Jul 2012 8:53pm
Page 2 of 5 <12345>
