![]() | Home > Technical > Electric window |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4812 ![]() ![]() |
Could be as simple as a dodgy contact or a loose connection.Mine went on the driver's window and it was a broken wire in the rubber covering sleeve that goes from the door frame to the pillar where the hinges are. The wire used is very frail. You can pull the sleeve gently out from the pillar at the bulk head and open it up to check the wires. 1982 88" 2.25 diesel
Thanks Guys will have a look at the wires and try Swapping the switches over...thanks for all the help
![]() will let you know ![]() |
Sorry - missed your reply. Thanks, all is clear now ![]() But shout it at them in German because life is also terrifying and confusing... |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20942 ![]() ![]() |
You will probably be able to remove the switches easily with out taking the dash out only the radio and access from the side only. This will be much easier for you then.
![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Thanks custom90steve, that's my job for Sunday then ![]() |
Good luck
Trossachs turbo Member Since: 14 Jul 2012 Location: Perthshire Posts: 21 ![]() ![]() ![]() |
Same happened to me,it was a broken feed wire (red) within the flexible conduit between the doorpost and door.it is a well known fault, the cables get stretched and fail.slit open the flexi conduit, and resealing with self amalg tape
Cheers Trossachs turbo, will check that 2moz when i have a play
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
Have you had a good pull at the wires between a post and door? If they are broken, which is very common, only the copper wire will be broken, not the insulation covering them.
Andy |
I had a good look will try again but they all seemed ok
Have you checked with a multimeter that there is power there? ____\We|Will|Win/___
No mate don't have one will get one of the lads to have a look....I'm not very good with wires
Ah right, If I was local you could have borrowed mine or I'd check it for you but not possible. I am wondering if perhaps it is a short now... ____\We|Will|Win/___
