Home > Puma (Tdci) > Best headlights? Brightest? |
Taken from a different thread....
After a few teething problems thankfully ironed out by Tim from Mobilecentre (thanks for going the extra mile! ) I have finally last week got round to fitting my J W Speakers. Whilst the cost is naturally quite prohibitive the cost has come down quite considerably since they were first available to the UK market, my previous headlights were totally useless in comparison. The light emitted is even noticable in broad daylight. I also got a pair of stainless retaining rings and as the OEM ones they are a very tight fit...... Couple of photos as requested Killer... Click image to enlarge Dipped beam....Rest of lights now on 'wishlist' to be converted to LED....J W Speaker naturally having seen them first hand at Tim's stand yesterday at B & W show.... Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
24th Jun 2012 11:36am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19608 |
That's a looker now Mal! Is the Safari snorkel always been on there or is it relatively new? Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
24th Jun 2012 12:03pm |
Kona,
I fitted it...must be three years ago now... Could always consider "I'vegotagreypairofsocks90' still better than 'Custom90steve' don't ya think? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
24th Jun 2012 12:10pm |
For some reason I thought it was new. Not sure where I got that from I should get one some time but then wants and needs Then again I don't think hardly any Pumas get used to a Snorkels capactiy i.e. over the bonnet Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
24th Jun 2012 12:26pm |
Mine doesn't even go offroad. Not ashamed to admit it the snorkel is for styling not functionality. If you go through life with your head in the sand....all people will see is an ar5e!!
24th Jun 2012 2:05pm |
Don't get me wrong I have no problem with it and I would too. Mine does the occasional green lane Byway but no off roading as such like going through 2 3 ft deep bombholes and water filled bogs So I too wouldn't need one. Best advantage I can see other than the real use is the cleaner lower dust quantity air drawn in from higher up than at the side. Around here with a lot of single track lanes in the summer a lot of dust gets kicked up on both side by the vegetation when driving past and seeing as the vent is right next to it it can't be a good thing. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
24th Jun 2012 2:23pm |
The only thing is with a performance exhaust/air filter etc. with a snorkel you lose the sweet 'intake growl' you get without one. If you go through life with your head in the sand....all people will see is an ar5e!!
24th Jun 2012 2:25pm |
I remember you mentioning that before. Anyway best not go on being off topic Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
24th Jun 2012 2:39pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
Yep...had a good nchat with Tim, Ada and Ian today. Led kit ordered and a happy customer.
Love the JW 110. must finish sound deadening the 110. |
24th Jun 2012 3:29pm |
