![]() | Home > Puma (Tdci) > Best headlights? Brightest? |
Jammer600 Member Since: 27 Feb 2011 Location: Bath/Warminster Posts: 306 ![]() ![]() ![]() |
What headlights should I get? I've got those Phillips bulbs in my standard lamps but my lights are still dull as fook on dipp!!?
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
Change headlamp units to crystal versions will help.............
As would uprated bulb [strictly for off road use] ![]() May need to 'man up' the wiring then though.. Guns and Landrovers .... anything else is irrelevant. |
Don't really wana mess about with the wiring, I've got rusty surrounds too, do the lights come with surrounds? My truck is a 57plate?
Def-00 Member Since: 11 May 2011 Location: Sharjah Posts: 236 ![]() ![]() ![]() |
Check out the speaker 8700. Expensive but well worth the money
http://www.defender2.net/forum/post105680.html#105680 2012 Fuji White 110 ![]() |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 ![]() ![]() |
I have got the cibe replacements in my 90 with Piaa bulbs very good light pattern, good white colour.
Europa parts for the light units and then mini spares for a set of stainless steel rings no rust ever (why oh why oh why dont they fit them at the factory) If everything is under control you are not going fast enough. Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
Cheers though id rather save �900 and stick with something a little cheaper but up to the job, cheers, I havnt got spots but just looked on tech part and someone's wired up spots through relay on dip beam? Even with four lights I'd still be about �700 better off?
scottish110 Member Since: 10 Nov 2011 Location: Inverurie Posts: 363 ![]() ![]() ![]() |
im putting the wipacs and phillips bulbs in today
I fitted them 2 weeks ago and they are a massive improvement. I thought about the LED ones too, but I'd be too worried about one getting damaged/failing after warranty (500 Euros gone ![]() My 110 has a few large stone chips on the front already (a light on my Audi was broken several years ago) - not sure how tough LED lamp glass is... Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Do you have the Minipart Pt No for the stainless retainer rings? Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
http://www.minispares.com/Product.aspx?ty=...amp;title= This the complete assy with the plastic bowl, i phoned them up and got the stainless bit separate ok If everything is under control you are not going fast enough. Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
Ok thanks ![]() Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
bartv Member Since: 03 Oct 2010 Location: Belgium Posts: 12 ![]() |
Minispares? Do these fit a Defender?
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 ![]() ![]() ![]() |
Yes. John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
BoltonBits do the stainless steel bezels/retainers. http://www.ebay.co.uk/itm/Defender-Stainle...2120wt_750 |
