Home > Puma (Tdci) > Best headlights? Brightest?
Page 2 of 3 <123>
RFT
United Kingdom 2010 Defender 130 Puma 2.4 HCPU Zermatt Silver
Wipac crystal with Osram night breaker lamps, and Hella FF75 spots relayed off main beam (all road legal) and now I can see where I am going at night.
My mounts were rusty to I'm going to get the SS ones from boltonbits soon. 130 Puma HCPU with an Artica 240LR Demountable Camper
Post #106422 12th Dec 2011 6:37pm
Jammer600
United Kingdom 2007 Defender 90 Puma 2.4 HT Tonga Green
An spots be wired to work the same as your main headlights ie dipp and full beam?
Post #106478 12th Dec 2011 9:12pm
RFT
No spots can only work on main beam, illegal to have them on on dip or dim dip. 130 Puma HCPU with an Artica 240LR Demountable Camper
Post #106490 12th Dec 2011 9:51pm
Jammer600
Whys that?
Post #106510 12th Dec 2011 10:36pm
ZeDefender
Jammer600 wrote:
Whys that?
High beams just light up everything, including the eyes of other drivers, as do spots (to some extent). They shouldn't be used with oncoming traffic.
Dipped beams are directed down and away from oncoming cars (an important MOT check). No other lights can interfere with this.
Hence spots should not be used with dips Smile Tell someone you love them today because life is short.
Post #106514 12th Dec 2011 10:43pm
Jammer600
So doesn't common sense tell us to point spots at the same place as dipp then?
Post #106561 13th Dec 2011 9:07am
ZeDefender
I suppose it all depends what you want to use them for.
In any event, the law has to cover all vehicles, including those of "spotty" boy racers whose "common sense" may be somewhat lacking Rolling Eyes Tell someone you love them today because life is short.
Post #106565 13th Dec 2011 9:36am
ZeDefender wrote:
Jammer600 wrote:
Whys that?
As far as I am aware you can have auxiliary lights which are on with dip beam as long as they do not and cannot dazzle oncoming drivers and their centres are a minimum of 600mm (used to be 2 feet) from the ground (if lower than this they are considered fog lights and can only be used in fog, falling snow, or nowadays other conditions of seriously reduced visibilty).
A spot beam auxiliary light probably doesn't make a lot of sense if it is fitted with the beam directed downwards sufficiently to ensure that it doesn't and cannot dazzle oncoming drivers, so doesn't tend to happen. I have, on several Land-Rovers I have run in the past (including my Disco2) fitted good quality aftermarket fog lights positioned with care to be just over 600mm from the ground. They are still low enough to work well as fog lights (better than LR headlights anyway) and with flat low beams they do not dazzle drivers. They are excellent for illuminating puddles/floods etc, and very useful on unmetalled roads for spotting holes etc. They are - as far as I can determine - fully legal to use either with or instead of dip beam.
The only trouble I have found using them is ignorant oncoming drivers assume, if you have dip plus aux lights on, that they are for lights and give you a blast of main beam, same as they might if you really were using fogs inappropriately. They do not dazzle oncoming drivers, but some oncoming drivers just hate you anyway!
Post #106571 13th Dec 2011 9:53am
ZeDefender
Conclusion Thumbs Up
i.e. spot + dip = barely legal, hardly useful and likely to get you flashed a lot (you may also have to explain the law to Plod if he stops you Shocked ) Tell someone you love them today because life is short.
Post #106577 13th Dec 2011 10:07am
Grockle
Lorryman100 wrote:
Miserableolgit wrote:
noworries4x4 wrote:
I have got the cibe replacements in my 90 with Piaa bulbs very good light pattern, good white colour.
Europa parts for the light units and then mini spares for a set of stainless steel rings no rust ever (why oh why oh why dont they fit them at the factory)
Do you have the Minipart Pt No for the stainless retainer rings?
BoltonBits do the stainless steel bezels/retainers.
http://www.ebay.co.uk/itm/Defender-Stainle...2120wt_750
cheers Lm 100,just ordered a pair Thumbs Up 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #106693 13th Dec 2011 6:23pm
rusty66
Germany
Hi, have you got the Landrover Parts Number for that? They say in their Ebay auction that it is a genuine part ...
Post #106704 13th Dec 2011 7:33pm
Jammer600
I spose I'd have to explain alot of things in that event!!
Post #107492 14th Dec 2011 8:33pm
ZeDefender
Rolling with laughter Tell someone you love them today because life is short.
Post #107497 14th Dec 2011 8:54pm
Lorryman100
Boris, check your email Thumbs Up
Post #107529 14th Dec 2011 10:46pm
What was the answer to this question (BoB listing this as a "Genuine Part" in "original Landrover packaging")?
Post #111973 4th Jan 2012 12:10pm
Page 2 of 3 <123>
