![]() | Home > Maintenance & Modifications > Dash tweeters |
yeah, like Russ says "I'd heard focal about them" ![]() - going to have a listen to some tomorrow though ![]() |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1196 ![]() ![]() |
Cheers Chad saw this last week ordered them, got them yesterday installed today and i am very impessed much better high end clarity not thrown to much bass at them yet but for £30 good cheap upgrade. Top recomendation If everything is under control you are not going fast enough. Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle Weekends MY 12 L322 4.4 TDV8 Vogue Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
Noworries,
Vibe is good gear! ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20916 ![]() ![]() |
What power RMS do you know? ![]() ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
550W RMS 1600W Peak. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
That's some punch! I'm hopefully planning one 450RMS and 900W peak (see avatar picture)
Mine came as a complete unit with the amp and speakers in an enclosure. As I hardly use the rear of my truck I wired it in on an umbillical so it can be moved anywhere in the rear dependant on load. Obviously the best place for it is facing forward at the rear door. If I had long hair I'd look like the geezer from The Range advert with the ear speaker when it's on.
Know the one ![]() ![]() ![]() ![]() ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
