Home > Maintenance & Modifications > Dash tweeters |
yeah, like Russ says "I'd heard focal about them" - going to have a listen to some tomorrow though |
4th Jun 2012 9:30am |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 |
Cheers Chad saw this last week ordered them, got them yesterday installed today and i am very impessed much better high end clarity not thrown to much bass at them yet but for 30 good cheap upgrade. Top recomendation If everything is under control you are not going fast enough. Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
10th Jun 2012 2:25pm |
Noworries,
Vibe is good gear! My subwoofer is Vibe and it's brilliant. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
10th Jun 2012 2:42pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19665 |
What power RMS do you know? Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
10th Jun 2012 2:46pm |
550W RMS 1600W Peak. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
10th Jun 2012 3:52pm |
That's some punch! I'm hopefully planning one 450RMS and 900W peak (see avatar picture) Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
10th Jun 2012 4:06pm |
Mine came as a complete unit with the amp and speakers in an enclosure. As I hardly use the rear of my truck I wired it in on an umbillical so it can be moved anywhere in the rear dependant on load. Obviously the best place for it is facing forward at the rear door. If I had long hair I'd look like the geezer from The Range advert with the ear speaker when it's on.
10th Jun 2012 4:11pm |
Know the one I use the rear all the time for stuff not always the cleanest of cargo either so I won't be doing that. I was going to make a custom cubby. Continue this on PM I don't really want to divulge all details of my plans or some ... will copy Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
10th Jun 2012 4:15pm |
