Home > Technical > Power loss in hot weather?
Page 2 of 7 <1234567>
Glynparry25
tatra805 wrote:
ZeDefender i bet the roaring is your viscous fan
Yeah, that is about right, mine does the same.
I must admit that I haven't had any temperature related speed issues in mine.... Mapped, filter and exhaust. It has been a constant high 20's for the past few weeks with nothing wrong.
Glyn Dog Sheep
Post #144781 13th May 2012 6:59pm
ZeDefender
Brilliant guys Bow down
Sounds exactly like it - it really is just for a few seconds and only after hammering the Autobahn in the heat Thumbs Up
Matt
p.s. I've got SO much to learn - I love this forum - cheers Martin Thumbs Up Tell someone you love them today because life is short.
Post #144786 13th May 2012 7:40pm
ZeDefender
I think the problem may have been the engine blanket combined with 32 degrees... it was red hot under there when I took it off Sad Tell someone you love them today because life is short.
Post #144789 13th May 2012 7:44pm
robpenrose
M Td5 does the same roar after being on the motorway, say at a roundabout just off it etc...
Also I have had it a few times just as I pull away first thing in the morning. Not happened very often, but only for a few secs. Current:D4 HSE
Gone: BMW Z4MC
Gone: Defender TD5 90 CSW
Previous: Discovery TD5 ES (Gone)
Post #144793 13th May 2012 7:53pm
Froggy
South Africa 2010 Defender 90 Puma 2.4 CSW Blenheim Silver
I had the same problem with my TD5 in 30+ Degs, particularly loss of power going up hills.
It would struggle for a while and be OK, especially if I turned the Aircon off.
Never got to the bottom it, because the weather got cooler Very Happy
Froggy Flying the flag in a country full of Toyota's!
Post #144802 13th May 2012 8:50pm
Regard
South Africa 2011 Defender 110 Puma 2.4 X-Tech LE Orkney Grey
Here in RSA we have a constant "struggle" with this exact problem.
Esp in summer when temps are constantly 30-35degC.
We have done a LOT of tests and all it came down to was the increased manifold intake temp measured by the MAP.
Only fix is silicone turbo hoses and larger intercooler.
Engine temp have no influence.........
Post #145062 15th May 2012 10:25am
Naks
It may also be worth to keep this in mind, as experienced by another Puma owner:
Quote:
as the Pumas get longer in the tooth, similar issues are being experienced to the Td5. excessive oil vapours coming off the tappet cover are landing in the inlet manifold. these vapours condense on the components. one of these components is the MAP sensor.
the resultant effect is that the MAP sensor starts failing and suddenly it feels like it is in limp mode. it starts off as an irritating intermittent issue but soon develops in a seriously annoying permanent issue.
remove the MAP sensor, clean with carb or electrical cleaner and refit.
it would be adviseable to keep a spare in the cubby.
it may be wise to remove intercooler and hoses, flush properly and refit.
this will at least buy time before the next round
Post #145064 15th May 2012 10:28am
ZeDefender
Took out my MAP this morning and it's covered in sh*tty black oil Shocked
Should I clean with diesel, petrol, nitrose thinners, or anything else I don't have to buy?
Matt Tell someone you love them today because life is short.
Post #145085 15th May 2012 12:09pm
Regard
Carburator cleaner or 99% medical alcohol.
The carb cleaner works better Thumbs Up
Post #145088 15th May 2012 12:13pm
ZeDefender
so not petrol then...
Strongest alcohol I have is vodka - looks like another trip to Obi Rolling Eyes Tell someone you love them today because life is short.
Post #145089 15th May 2012 12:25pm
pope10001
United Kingdom 1992 Defender 90 200 Tdi HT Zermatt Silver
I have absolutely no problems with my 2009 Tdci in anything unto 55C still does 160kph all day long, well till the fuel runs out anyway... lol It does have an uprated intercooler, hoses and chip though
Post #146306 21st May 2012 7:36pm
ZeDefender
I am beginning to think the intercooler is the key... Tell someone you love them today because life is short.
Post #146308 21st May 2012 7:45pm
Naks
Yep, all evidence points to that. --
Post #146309 21st May 2012 7:46pm
Naks
Seen on a South African forum:
Quote:
I just spoke to a very clued-up head tech guy at LR yesterday.
The good news is that they are VERY aware of the "power loss in high ambient temps" that so many of us struggle with.
Even better news is that he is part of a "global team" to takle this problem and he told me that LRUK just installed a brand new "wind tunnel" in which they will run the cars at temps of 35-38 degC to see where the fault lies!
The LR Centurion Defender was just fitted with a bigger intercooler that solved the problem but we are all waiting for the "official" fix from LRUK
Just mentioning it..............
Post #146680 23rd May 2012 3:41pm
ZeDefender
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Tell someone you love them today because life is short.
Post #146682 23rd May 2012 3:52pm
