![]() | Home > Technical > Power loss in hot weather? |
Brilliant guys ![]() Sounds exactly like it - it really is just for a few seconds and only after hammering the Autobahn in the heat ![]() Cheers Matt p.s. I've got SO much to learn - I love this forum - cheers Martin ![]() But shout it at them in German because life is also terrifying and confusing... Last edited by ZeDefender on 13th May 2012 7:51pm. Edited 1 time in total |
I think the problem may have been the engine blanket combined with 32 degrees... it was red hot under there when I took it off ![]() But shout it at them in German because life is also terrifying and confusing... |
robpenrose Member Since: 15 Jan 2011 Location: Hampshire or Cornwall Posts: 338 ![]() ![]() |
M Td5 does the same roar after being on the motorway, say at a roundabout just off it etc...
Also I have had it a few times just as I pull away first thing in the morning. Not happened very often, but only for a few secs. Current:D4 HSE Gone: BMW Z4MC Gone: Defender TD5 90 CSW Previous: Discovery TD5 ES (Gone) |
Froggy Member Since: 01 Apr 2012 Location: Stellenbosch South Africa Posts: 17 ![]() ![]() ![]() |
I had the same problem with my TD5 in 30+ Degs, particularly loss of power going up hills.
It would struggle for a while and be OK, especially if I turned the Aircon off. Never got to the bottom it, because the weather got cooler ![]() Froggy Flying the flag in a country full of Toyota's! |
Regard Member Since: 08 Dec 2011 Location: RSA Posts: 251 ![]() ![]() ![]() |
Here in RSA we have a constant "struggle" with this exact problem.
Esp in summer when temps are constantly 30-35degC. We have done a LOT of tests and all it came down to was the increased manifold intake temp measured by the MAP. Only fix is silicone turbo hoses and larger intercooler. Engine temp have no influence......... |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673 ![]() ![]() ![]() |
It may also be worth to keep this in mind, as experienced by another Puma owner:
. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Took out my MAP this morning and it's covered in sh*tty black oil
![]() Should I clean with diesel, petrol, nitrose thinners, or anything else I don't have to buy? Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Carburator cleaner or 99% medical alcohol.
The carb cleaner works better ![]() |
so not petrol then...
Strongest alcohol I have is vodka - looks like another trip to Obi ![]() But shout it at them in German because life is also terrifying and confusing... |
pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489 ![]() ![]() ![]() |
I have absolutely no problems with my 2009 Tdci in anything unto 55C still does 160kph all day long, well till the fuel runs out anyway... lol It does have an uprated intercooler, hoses and chip though
I am beginning to think the intercooler is the key... Tell someone you love them today because life is short.
Yep, all evidence points to that. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Seen on a South African forum:
![]() ![]() ![]() ![]() ![]() But shout it at them in German because life is also terrifying and confusing... |
