![]() | Home > Tdi > 300tdi fitting a new aux belt |
sense of adventure Member Since: 11 Nov 2011 Location: warwickshire Posts: 147 ![]() ![]() ![]() |
10 minutes max, very easy
15mm socket on a knuckle bar to remove to tension and a 15mm spanner needed, it's pretty self explanatory just take note of the belt track |
cheer SoA ... I'll pick up a belt tomorrow and have a go ... just never done it before
found it in the 300tdi WSM ... looks like I can do that ![]() |
LRSoffroad Member Since: 15 Feb 2012 Location: Doncaster Posts: 189 ![]() ![]() |
Dead easy bpman you will have it done in no time
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8366 ![]() ![]() ![]() |
POP, as above 15mm socket on a breaker bar is all you need. 2mins. Cheers
MrsBPMan is going to collect one tomorrow and I'm going to do it tomorrow night ..
how long should the OE belts last ? Mine's less than a year old ... (and don't tell me off roading has shortened it's life ... it's a land rover ![]() |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
Suggest you take the engine number as there are 2 belt lengths and I found MY didnt help. BM52
my old 300 defender belt lasted 3 years (no air con) my old 300 disco with ac would last about 9-12 months.
check pulley bearings, water pump etc for wear and alignment before refitting, also your tensioner may start to squeal with a new belt, use silicone spray on the belt (not wd40!) and white grease as appropriate on the tensioner pulley. |
found a video ...
http://www.youtube.com/watch?v=aipB15NArOc |
all done, 10 minute job .. all done and tested
![]() good call BM52, I called the dealer with the chassis number they found the right one. |
tod you easy as pie
yyyyuuupp
