Home > Tdi > 300tdi fitting a new aux belt
how tricky is it to fit a new aux. belt on a 300tdi ? I've noticed mine has a started to look quite worn.
anyone got a how to ?
Post #140924 22nd Apr 2012 6:58pm
sense of adventure
United Kingdom 2010 Defender 110 Puma 2.4 USW Galway Green
10 minutes max, very easy
15mm socket on a knuckle bar to remove to tension and a 15mm spanner needed, it's pretty self explanatory just take note of the belt track
Post #140926 22nd Apr 2012 6:59pm
cheer SoA ... I'll pick up a belt tomorrow and have a go ... just never done it before
found it in the 300tdi WSM ... looks like I can do that Thumbs Up
Post #140929 22nd Apr 2012 7:06pm
LRSoffroad
Dead easy bpman you will have it done in no time Thumbs Up
Post #140949 22nd Apr 2012 7:58pm
jst
POP, as above 15mm socket on a breaker bar is all you need. 2mins. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #140952 22nd Apr 2012 8:07pm
MrsBPMan is going to collect one tomorrow and I'm going to do it tomorrow night ..
how long should the OE belts last ? Mine's less than a year old ... (and don't tell me off roading has shortened it's life ... it's a land rover Laughing )
Post #140967 22nd Apr 2012 8:38pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Suggest you take the engine number as there are 2 belt lengths and I found MY didnt help. BM52
Post #141003 22nd Apr 2012 10:06pm
bm52
Post #141004 22nd Apr 2012 10:07pm
sense of adventure
my old 300 defender belt lasted 3 years (no air con) my old 300 disco with ac would last about 9-12 months.
check pulley bearings, water pump etc for wear and alignment before refitting, also your tensioner may start to squeal with a new belt, use silicone spray on the belt (not wd40!) and white grease as appropriate on the tensioner pulley.
Post #141006 22nd Apr 2012 10:12pm
Post #141036 23rd Apr 2012 7:33am
all done, 10 minute job .. all done and tested Thumbs Up
good call BM52, I called the dealer with the chassis number they found the right one.
Post #141200 23rd Apr 2012 7:28pm
bm52
Thumbs Up BM52
Post #141203 23rd Apr 2012 7:35pm
LRSoffroad
tod you easy as pie Mr. Green
Post #141266 23rd Apr 2012 9:26pm
yyyyuuupp Thumbs Up
Post #141277 23rd Apr 2012 10:02pm
