![]() | Home > Puma (Tdci) > Gap door/window |
| ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731
Mine is like that on one side and not on the other - good old LR build quality
Are you sure you didn't miss spotting it (on that side) before? Surely if someone tried to force it: a) they would succeed, and b) there would be other marks My guess is a change in temperature. Not sure if the skins are pulled in by something that can loosen off - someone else will surely know Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
| spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4812
Is that the rubber weathershield? If so I had to remove one of mine and cut a small piece off of it as it was a little too long. Now it is a snug fit. 1982 88" 2.25 diesel
Thinking a bit harder, where exactly is the gap? I assumed along the bottom but "between the doorframe and the window" covers a lot of ground... Tell someone you love them today because life is short.
| Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6346
same as mine. didn't notice it to start with but now I do....
just wondering if the likes of dentmaster etc can do something with it? |
| XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632
My mates Puma was exactly like that on the nearside from new. I teased it back into position using an iPod opening tool. A year on it's still where I left it.
Pete |
Exactly where is the gap, please? I'm now a bit confused (as usual). (sorry if that seems a stupid question) Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
If you look at the picture, you can see a narrow gap between the bottom of the rubber window sealing strip, and the glass aperture in the door which runs pretty much the whole width of the window. This is supposed to be covered by the rubber strip, but often isn't in many cases.
Pete |
Aha! Cheers, that's what I thought.
So you took the rubber off and prized something back in? Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
| Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026
Just push the rubber back down and out
Cheers Zag. My door skin is so warped the rubber won't stretch that far - another job for Summer - good old Sikaflex But shout it at them in German because life is also terrifying and confusing... |
You don't need to take it off. Like Zag said, if you push it down it will spread out a bit towards the edge of the door. If you then slip something underneath the edge of it where it should touch the metal work (something flat and plastic so as not to cause damage - I used a flat iPod opening tool which is perfect for the job), you can gently pull the bottom edge outwards which will cover the gap. It seems to slightly reposition it and it stays there - it certainly did on the one I fixed for someone
Pete |
| Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266
same on ours doesn't cause any problems 2.4 90 XS
Only that you're getting unnecessary water inside the door. Pete |
Mine is bowed so much the rubber can't move far enough - no way Jose
It's also touch and go on the other side I'll look into wider seals or else...da, da, da - the Sikaflex... Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
