![]() | Home > Puma (Tdci) > How to determine if I have a lift |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2291 ![]() ![]() ![]() |
You can measure the distance between axle and bump stops or between the tire rim edge to the plastic fenders and then compare with someone who has a 90". Puma 110" SW
LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11240 ![]() ![]() ![]() |
If you measure vertically from the wheel centre to the edge of the wheelarch eyebrow, then it avoids variations in wheel or tyre sizes. However, as MK says, you'll need the same measurements from a known stock vehicle to compare with.
As a rule of thumb though, the height to the top of the roof at the rear should be around 2050 mm. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
Kona,
do one of the measurments mentioned and request some one on standard springs to do the same? Mark |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19750 ![]() ![]() |
Good idea will have a look tomorrow. I think it's probably +2"
Still not managed to get round to measuring
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10367 ![]() ![]() |
I have to walk up the stairs, so I know !!!!
Sorry ! |
Tell me about it
Height from the centre of rear hub to roof gutter is 144cm. Now I just need someone with a 90 on standard springs to measure too. Anyone that can do this I would appreciate it
Honker Member Since: 26 Jun 2011 Location: St Albans Posts: 353 ![]() ![]() ![]() |
Std springs and wheels - bilstein shocks but that shouldn't do much to ride height ........143cm
You've a 10mm lift ![]() Stu |
10mm Yayyy
Is it possible they're a different rating to the std one ?
Stu |
They do seem very good and flexable so softer than OE I would imagine. I have no idea what has been done with it in that respect because mine was dealer bought. Someone in Wales that had it from new and exchanged for a new Disco winter 2009
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
park it next to mine if you want
AFAIK, is a 110 not higher at the rear than a 90? ![]() |
