Home > Puma (Tdci) > How to determine if I have a lift
My 90 Puma has has Yellow springs on since I've had it. I'm the second owner. I'm assuming that it will be lifted or atleast I know that they're not standard. Is there a simple way of measuring with out taking anything apart and if so what would be the measurements be? Thumbs Up
Post #123410 12th Feb 2012 1:13pm
MK
You can measure the distance between axle and bump stops or between the tire rim edge to the plastic fenders and then compare with someone who has a 90". Puma 110" SW
Post #123426 12th Feb 2012 4:16pm
If you measure vertically from the wheel centre to the edge of the wheelarch eyebrow, then it avoids variations in wheel or tyre sizes. However, as MK says, you'll need the same measurements from a known stock vehicle to compare with.
As a rule of thumb though, the height to the top of the roof at the rear should be around 2050 mm. Darren
Post #123428 12th Feb 2012 4:35pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
Kona,
do one of the measurments mentioned and request some one on standard springs to do the same?
Mark
Post #123438 12th Feb 2012 5:12pm
Good idea will have a look tomorrow. I think it's probably +2"
Post #123475 12th Feb 2012 6:39pm
Still not managed to get round to measuring Embarassed Must do it tomorrow Laughing
Post #124754 17th Feb 2012 7:11pm
I have to walk up the stairs, so I know !!!!
Sorry !
Post #124844 17th Feb 2012 10:05pm
Tell me about it Razz Just need to find some one that has a 90 on standard springs. Anyone?
Post #124854 17th Feb 2012 10:35pm
Height from the centre of rear hub to roof gutter is 144cm. Now I just need someone with a 90 on standard springs to measure too. Anyone that can do this I would appreciate it Thumbs Up
Post #125177 19th Feb 2012 2:47pm
Honker
 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
Std springs and wheels - bilstein shocks but that shouldn't do much to ride height ........143cm
You've a 10mm lift Very Happy
Stu
Post #125214 19th Feb 2012 5:28pm
10mm Yayyy Rolling with laughter I have from the previous owner standard shocks but Yellow springs. Still confused did they change from LR OE to aftermarket without a lift Question Confused Question
Post #125216 19th Feb 2012 5:40pm
Honker
Is it possible they're a different rating to the std one ?
Stu
Post #125217 19th Feb 2012 5:42pm
They do seem very good and flexable so softer than OE I would imagine. I have no idea what has been done with it in that respect because mine was dealer bought. Someone in Wales that had it from new and exchanged for a new Disco winter 2009
Post #125218 19th Feb 2012 5:44pm
T1G UP
park it next to mine if you want
Post #125219 19th Feb 2012 5:59pm
AFAIK, is a 110 not higher at the rear than a 90? Thumbs Up
Post #125225 19th Feb 2012 6:15pm
