Home > Puma (Tdci) > How to determine if I have a lift |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2291 |
You can measure the distance between axle and bump stops or between the tire rim edge to the plastic fenders and then compare with someone who has a 90". Puma 110" SW
12th Feb 2012 4:16pm |
If you measure vertically from the wheel centre to the edge of the wheelarch eyebrow, then it avoids variations in wheel or tyre sizes. However, as MK says, you'll need the same measurements from a known stock vehicle to compare with.
As a rule of thumb though, the height to the top of the roof at the rear should be around 2050 mm. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
12th Feb 2012 4:35pm |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 |
Kona,
do one of the measurments mentioned and request some one on standard springs to do the same? Mark |
12th Feb 2012 5:12pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19750 |
Good idea will have a look tomorrow. I think it's probably +2"
12th Feb 2012 6:39pm |
Still not managed to get round to measuring Must do it tomorrow
17th Feb 2012 7:11pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10367 |
I have to walk up the stairs, so I know !!!!
Sorry ! |
17th Feb 2012 10:05pm |
Tell me about it Just need to find some one that has a 90 on standard springs. Anyone?
17th Feb 2012 10:35pm |
Height from the centre of rear hub to roof gutter is 144cm. Now I just need someone with a 90 on standard springs to measure too. Anyone that can do this I would appreciate it
19th Feb 2012 2:47pm |
Honker Member Since: 26 Jun 2011 Location: St Albans Posts: 353 |
Std springs and wheels - bilstein shocks but that shouldn't do much to ride height ........143cm
You've a 10mm lift Stu |
19th Feb 2012 5:28pm |
10mm Yayyy I have from the previous owner standard shocks but Yellow springs. Still confused did they change from LR OE to aftermarket without a lift
19th Feb 2012 5:40pm |
Is it possible they're a different rating to the std one ?
Stu |
19th Feb 2012 5:42pm |
They do seem very good and flexable so softer than OE I would imagine. I have no idea what has been done with it in that respect because mine was dealer bought. Someone in Wales that had it from new and exchanged for a new Disco winter 2009
19th Feb 2012 5:44pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
park it next to mine if you want
19th Feb 2012 5:59pm |
AFAIK, is a 110 not higher at the rear than a 90? |
19th Feb 2012 6:15pm |
