Home > Maintenance & Modifications > Door Stuck Shut
Waldo
Door Stuck Shut
Hi guys my front passenger door is shut and I cannot open it from either the inside or outside handles.
Is there any way to open it by fiddling with the visible portion of the lock down by the seat, or am I going to have to rip the door card out.
Once it's open I know what I'm doing to get inside and find the problem. It would be easier to have the door open though to get the card off and access the locking mechanisms.
Any ideas?
I'm in an 03 Td5 90 XS
Regards
Will Defender 90 XS TD5 (03 Reg)
Post #112822 6th Jan 2012 11:05am
T1G UP
slim jim down the inside of the glass?
Post #112844 6th Jan 2012 11:53am
Zagato
Deleted
Post #112875 6th Jan 2012 12:59pm
Zagato wrote:
deleted
on an open forum Zag Shocked
Post #112884 6th Jan 2012 1:28pm
Waldo
I've manage to get in with some nifty work with a strong piece of wire Smile
Only issue is now that I've got it open I can't find what the problem is.
The door now opens and shuts fine from inside and out but I haven't adjusted anything!!
Very confused. Ideas?
Post #112901 6th Jan 2012 2:36pm
JWL
Ah, you must have depressed the "Girly/Jeep" button and got it back to working properly Whistle
Post #112904 6th Jan 2012 2:40pm
BigMike
Take the door card off and have a look. There is no need to "rip it off", just use a butter knife or whatever to gently lever it.
Post #112921 6th Jan 2012 4:44pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
I think the problem Big Mike was that the door was shut - this would make getting the door card off a little difficult. Once the door is open, as it now is, he was able to remove the door card in the accepted manner. Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #112932 6th Jan 2012 5:21pm
rossy
or maybe he used a fish knife instead of a butter knife ? Laughing
Post #113131 7th Jan 2012 1:02am
BigMike
Or a posh fish slice Laughing
point taken WG
Post #113135 7th Jan 2012 2:51am
Nick T
England 2010 Defender 90 Puma 2.4 HT Galway Green
Check the hinges for play-this happened to me, same symptoms.
Post #113139 7th Jan 2012 7:14am
chiefstoker
England 2005 Defender 90 Td5 HT Zambezi Silver
Please report your findings Waldo Confused Thumbs Up 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy
Post #113140 7th Jan 2012 8:07am
Waldo
Even though after opening the door it resumed normal working I made one change
What I've done is adjusted how far the push button moves the lever which opens the lock by decreasing the amount of thread below the nut the control rod goes through.
I will check the hinges for play tomorrow Nick thanks for the advice.
I did previously have the problem that the passenger wouldn't open from the outside and did the same adjustment as above.
At the moment i'm driving round with no door card so if it does get stuck again i hope to find the problem before opening and fixing.
The only thing that I can think of that may be the problem is that some part of the lock may not be secured so is flexing on it's mountings.
Therefore the rods don't move the piece they are attached to enough to open the lock.
Lastly, does anyone know where I can get some replacement retaining clips?
The ones that hold the trim piece onto the door, some were snapped off on removal.
Post #113213 7th Jan 2012 4:21pm
Waldo
New development.
It hasn't been fixed with the adjustment.
The door came open today whilst driving and i had to bungee cord it shut as you do.
It then got stuck half shut if that makes sense.
So I couldn't open it with either outside push button or inside handle.
After a lot of fiddling with the lock button which moves when you use the central locking as well as the lever which the outside button pushes up i got it open. Slammed the door and it was fine on the way home.
So what do you think, actuator??
Mechanism moving on it's housing?
Door dropped?
I have no idea where to start.
Post #113926 9th Jan 2012 11:00pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
have you taken the door card of the other front door and compared how the linkage is set up, could be a bent rod or a disconnected link.
also worth checking that the outside door button is not sticking part way depressed. suggest liberal lubricating of all linkages, door button, lock barrel and catch. BM52
Post #113932 9th Jan 2012 11:15pm
