![]() | Home > Maintenance & Modifications > Fitting of Synthetic Rope |
chopdogs Member Since: 10 Mar 2010 Location: Wiltshire Posts: 108 ![]() ![]() ![]() |
Hi All
Quick question for you. I'm replacing the wire on my winch with synthetic rope. Do I need to tension it when fitting - as you would with wire? Warn say "The life of a wire rope is directly related to the use and care it receives. During its first use, a new wire rope must be spooled onto its drum under a load of at least 1000 lbs. (454 kgs)." Is this the same for synthetic rope? Thanks |
Thanks Ken
Fairlead will be replaced by a hawse ![]() The excerpt from the Warn manual was specifically referencing the first time the wire is spooled onto the drum - basically saying that when first fitting the wire it needs to be under considerable tension. Is this also true of synthetic rope? |
As Ken says there will be many different views on this subject.
A few ideas worth considering. You need to keep at least the last five if not 8-10 turns of the rope on the drum. Either have count down markers on your rope or use a rope keeper to prevent last turns being spooled out. Under free spool conditions I have seen a synthetic rope pulled off its retaining ferrule. Yes synthetic ropes should be spooled on tidily however in a different way to wire rope. Bottom layer goes on as per wire rope, next layer goes on at about 15 degrees to the normal direction, the following layer goes on at about 15 degrees to the other side of the normal. Why? If you spool on in the conventional manner then when you deploy the rope and spool back on under load it is possible for the top layer of synthetic rope to bury itself in the layers underneath. To say it can be awkward to redply rope is an understatement. I have seen where the winch rope will not free spool out but had to be pulled out by a motor as rope was so tightly buried. If the layer underneath is at an angle the top layer will not bed itself down. Hope that makes sense. Used with sense synthetic ropes are good, however do not believe the marketing hype that synthetic ropes do not fly when they break. YES they can fly, maybe not as dangerous as a steel rope but I would not want a flying synthetic rope anywhere near my eyes. Treat them as dangerous as a steel rope, i.e. keep unnecessary people out of the danger zone. Danger zone is two circles centred on winch and anchor with a radius equal to length of rope paid out. Keep all unnecessary people out of that area. Treat ANY recovery operation as a dangerous event and use all precautions. Just because something is SAFER it does not make it SAFE. Brendan |
Lookers Park Royal Member Since: 19 Jun 2008 Location: London Posts: 338 ![]() ![]() |
I never knew that, however if makes perfect sense, AND I had the exact problem you have outlined whilst helping someone free-spool a synth rope which had been spooled in the same way as a wire rope is usually spooled................ it was a nightmare! James ![]() |
It does take slightly longer to do but the slightly longer time taken to spool the synthetic neatly and correctly can be very well worth while when you need to use the winch, because then it will be dark/muddy/raining/tired etc etc
Brendan |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2702 ![]() ![]() |
The 15 deg angle is not necessary if you put the rope on under tension. And that means winch in the full length of the rope dragging the car along, not all wheels locked up but with the brakes acting on the disks. It should make the winch work a bit, you'll know this by the sound of the motor. Only pull off exactly how much you need for the recovery and then all will be fine and you won't have the upper layer biting into the lower layer. 110 D250 SE HT
110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
Thnak Brendan - very sound advice!
Does it need to be under load during the first ever spooling (ie when installing)? |
Deleted - double post
Thanks Walfy - our posts crossed
I'll do that! |
v8steve Member Since: 18 Apr 2011 Location: dumfries scotland Posts: 195 ![]() ![]() ![]() |
have had a couple of syn ropes snap on challenges cheap one a bit of flying about but now't to worry about.
quality rope dropped straight down no dramma at all. i have heard about the15 degrees/overlap thing. but how are you supposed to do that with 2 ton plus strain on the rope? just put in on under tension from day one. it may dig down sometimes but a small price to pay for the safety and eases of handling. merry crimbo to all 110 xs s/wagon s3 swb soft top |
But then you have the issue that the pulling power of the winch is hugely reduced the more layers of rope you have on it. You get the max pull from the rope on the first layer. When you reach the second you've lost around 30% of the pulling power, then same again on the third layer. What Brendan said is absolutely right re the angled turns, but I do agree with you that if the rope is under tension when it's rolling in, it's less likely to 'cut" through to the lower layers. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8338 ![]() ![]() ![]() |
i agree totally with Walfy and have probably had more winch use then most with synthetic over the years. If its on under load then it wont bite in. If you put it on without load, add some angles to stop if biting through. Only pull off the amount of rope you need as Walfy says then there will be no slack going back on the drum to cause a potential 'bite through' later. you are correct you loose approx 1000lb of pull for every layer on a drum, hence extended and narrower drums. I always fit mine under tension, drag weight of the vehicle with a little braking works fine. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
brainscott Member Since: 11 Feb 2012 Location: Australia Posts: 1 ![]() ![]() |
Hey there..!! Nice stuff..!! Thank you for sharing it with us.
___________________________________ wire rope |
