![]() | Home > Technical > Long term diesel storage |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026 ![]() ![]() |
It depends on what type of diesel you are storing. I'll leave it to the experts to comment but my understanding is that the later type of diesel is not so good for storing because of the higher bio content. Certainly with inboard boat engines and fuel that are left for 4-5 months during the winter plenty of stabilizing additive is needed to prevent diesel bug. Marine diesel is different again though to forecourt stuff!
Farmers do it so there must be a way depending on the type of diesel! |
lrMike Member Since: 26 Feb 2010 Location: Athens Posts: 177 ![]() ![]() |
The type of diesel is automotive (The normal one sold in every fuel station).
Mike |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
You'd need a bud to catch fuel if it leaked - or by a double skinned tank instead of the barrels www.highspeed.co.uk/bunded-fuel-tanks
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2702 ![]() ![]() |
Why the need to store so much fuel?? When I get excess fuel it goes into mil jerrycans. Not the cheap nasty thin civvy copies. Does me fine. Never seen 1 leak in all the 23 yrs I was serving
![]() 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
TACK Member Since: 26 Apr 2009 Location: Essex Posts: 1045 ![]() ![]() |
Company fuel card ![]() |
Diesel storage shouldn't be a problem but as with any mixture of chemicals it will start to separate as it settles in the tank.
The only other issue you will have is the fuel will expand and contract with the heat and you can get condensate gathering at the top of the barrel, but you also need to leave an air gap for the fluid to expand and contract with the heat. If you are worried you should keep the fuel agitated every so often. What every you do do not try and store the Shell fuel saver diesel. Russell 2011MY 110 XS USW Black |
... why is that Russ ? |
That was good Tack ![]() Actually I was thinking of Shell fuel saver since this is what I ususally put in my def. Very interested to know why not that... |
Well their fuel doesn't work every well in the winter People have had to drain tanks and replace fuel filters due to the additives being put in Buying that doesnt line my pockets nor yours ![]() Need I say more? Russell 2011MY 110 XS USW Black |
![]() ![]() ![]() 2011MY 110 XS USW Black |
Not necessarily, in Greece their Health & Safety rules may differ pertaining bunds..... Elf ![]() & Safety... ![]() ![]() During the fuel crisis I too stored fuel in 2 fifty gallon drums I always worried about insurance implications if it did go up. Don't think I'd do it again, too many sleepless nights. ![]() Treat every day as if it is your last....one day you will be right!! |
I wasn't going to say that but ![]() |
Thank you for your help folks,
To sum it up I keep in mind the following: 1. The barrels must be filled to the top in order to avoid any condensation but not totaly full in order to have place for air expansion. 2. Great care must be taken not to hit the barrel and cause any leakage because the rules here are the same as in the UK. 3. Better to avoid Shell fuel saver due to the additives so I will go for BP or some local brand. 4. Must agitate the fuel from time to time. Is that all? Mike. |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4812 ![]() ![]() |
Why not get a proper storage tank (1100 litres) with a filler hose and nozzle? I have had one for years without any bother. Also the diesel comes in a bit cheaper when bought in bulk, especially before price increases. It is also very convenient as you can top up any time. 1982 88" 2.25 diesel
