Home > Technical > Long term diesel storage
lrMike
Greece
I was wondering if somebody ever wanted to store diesel fuel in the usual 200lt barrels what would be the "life span" of the fuel itself so that it could be used to run the Puma engine?
Considering the following:
1) The barrels would be filled to the top to avoid condensation as much as possible
2) The barrels would be placed outdoors but under a covered area with temperatures from -10 to +30 deg. C and no direct rain, snow or sunlight.
I hope I get some answers from the experts here Thumbs Up because I might decide to store some for future use.
Cheers,
Mike
Post #107814 16th Dec 2011 3:06pm
Zagato
It depends on what type of diesel you are storing. I'll leave it to the experts to comment but my understanding is that the later type of diesel is not so good for storing because of the higher bio content. Certainly with inboard boat engines and fuel that are left for 4-5 months during the winter plenty of stabilizing additive is needed to prevent diesel bug. Marine diesel is different again though to forecourt stuff!
Farmers do it so there must be a way depending on the type of diesel!
Post #107816 16th Dec 2011 3:17pm
lrMike
Greece
The type of diesel is automotive (The normal one sold in every fuel station).
Mike
Post #107818 16th Dec 2011 3:22pm
Romadog
You'd need a bud to catch fuel if it leaked - or by a double skinned tank instead of the barrels www.highspeed.co.uk/bunded-fuel-tanks
Post #107874 16th Dec 2011 6:28pm
walfy
Why the need to store so much fuel?? When I get excess fuel it goes into mil jerrycans. Not the cheap nasty thin civvy copies. Does me fine. Never seen 1 leak in all the 23 yrs I was serving Thumbs Up 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #107916 16th Dec 2011 8:49pm
TACK
Company fuel card Rolling with laughter
Post #108001 17th Dec 2011 9:32am
BigRuss
Diesel storage shouldn't be a problem but as with any mixture of chemicals it will start to separate as it settles in the tank.
The only other issue you will have is the fuel will expand and contract with the heat and you can get condensate gathering at the top of the barrel, but you also need to leave an air gap for the fluid to expand and contract with the heat.
If you are worried you should keep the fuel agitated every so often.
What every you do do not try and store the Shell fuel saver diesel. Russell
2011MY 110 XS USW Black
Post #108030 17th Dec 2011 11:35am
... why is that Russ ?
Post #108033 17th Dec 2011 11:42am
lrMike
Greece
That was good Tack Laughing I wish I had one...
Actually I was thinking of Shell fuel saver since this is what I ususally put in my def. Very interested to know why not that...
Post #108038 17th Dec 2011 12:26pm
BigRuss
Well their fuel doesn't work every well in the winter
People have had to drain tanks and replace fuel filters due to the additives being put in
Buying that doesnt line my pockets nor yours Whistle
Need I say more? Russell
Post #108040 17th Dec 2011 12:30pm
BigRuss
Whistle Whistle Whistle Russell
Post #108041 17th Dec 2011 12:30pm
K9F
Not necessarily, in Greece their Health & Safety rules may differ pertaining bunds.....
Elf
& Safety... Rolling with laughter
During the fuel crisis I too stored fuel in 2 fifty gallon drums I always worried about insurance implications if it did go up. Don't think I'd do it again, too many sleepless nights. Whistle If you go through life with your head in the sand....all people will see is an ar5e!!
Post #108046 17th Dec 2011 1:15pm
Need I say more?
I wasn't going to say that but Thumbs Up
Post #108048 17th Dec 2011 1:17pm
lrMike
Greece
Thank you for your help folks,
To sum it up I keep in mind the following:
1. The barrels must be filled to the top in order to avoid any condensation but not totaly full in order to have place for air expansion.
2. Great care must be taken not to hit the barrel and cause any leakage because the rules here are the same as in the UK.
3. Better to avoid Shell fuel saver due to the additives so I will go for BP or some local brand.
4. Must agitate the fuel from time to time.
Is that all?
Mike.
Post #108070 17th Dec 2011 3:41pm
spudfan
Ireland
Why not get a proper storage tank (1100 litres) with a filler hose and nozzle? I have had one for years without any bother. Also the diesel comes in a bit cheaper when bought in bulk, especially before price increases. It is also very convenient as you can top up any time. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #108137 18th Dec 2011 1:53am
