![]() | Home > General & Technical (L663) > Failed dune climb. Gearbox selection when sand driving |
| WOZnet Member Since: 18 Nov 2024 Location: Auckland Posts: 2
When on a trip recently and attempting a steep sand dune climb I had the following issue.
With drive mode set for SAND and in Auto, with a good run up the vehicle climbed well at full throttle but at about two thirds of the way up the auto changed up which caused the vehicle to immediately bog down. After a couple of attempts I tried in manual mode, vehicle would only allow srart in second gear which didn't provide enough momentum at the beginning of the run and third gear, the preferred option on the hill was not selectable from a start. My question is, has anyone any suggestions on a different approach to this situation? Vehicle= 2023 P400S 110 running Wrangler MT,s. |
| revd Member Since: 20 Apr 2024 Location: England Posts: 308
take out the spark plugs, reverse gear and wind it up the hill on the starting handle
?si=lAL5JpBqNwCWTNDy |
| Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3788
Could you start in GGS in first gear manual, shift to second then move into sand mode and go from there?
| kenl Member Since: 11 Jul 2022 Location: bunvegas Posts: 35
AS mentioned it sounds like stability control had not been turned off?
Thanks Guys,
Correct, stability control not turned off. I'll try that on the next run. |
| All times are GMT |
