Home > General & Technical (L663) > Failed dune climb. Gearbox selection when sand driving
WOZnet
New Zealand
When on a trip recently and attempting a steep sand dune climb I had the following issue.
With drive mode set for SAND and in Auto, with a good run up the vehicle climbed well at full throttle but at about two thirds of the way up the auto changed up which caused the vehicle to immediately bog down. After a couple of attempts I tried in manual mode, vehicle would only allow srart in second gear which didn't provide enough momentum at the beginning of the run and third gear, the preferred option on the hill was not selectable from a start.
My question is, has anyone any suggestions on a different approach to this situation?
Vehicle= 2023 P400S 110 running Wrangler MT,s.
Post #1078645 29th Oct 2025 9:53am
revd
take out the spark plugs, reverse gear and wind it up the hill on the starting handle
?si=lAL5JpBqNwCWTNDy
Post #1078648 29th Oct 2025 9:56am
Co1
Could you start in GGS in first gear manual, shift to second then move into sand mode and go from there?
Post #1078713 29th Oct 2025 6:57pm
Huwcil
Re: Failed dune climb. Gearbox selection when sand driving
Turn the stability control off. Even when it is switched off, it isn’t quite 100% off but it does stop the engine from limiting power and revs to a great extent. If you have the facility, set a configurable off-road driving mode to pre-lock you centre diff lock and rear if you have a locking rear. There are all kinds of options in there to choose from. You can program up to four extra custom modes and if you quickly choose one, the last used will be the default. You can quickly change that to another mode or edit a mode for the particular conditions encountered.
Post #1078731 29th Oct 2025 9:35pm
kenl
Australia
AS mentioned it sounds like stability control had not been turned off?
Post #1078735 29th Oct 2025 9:59pm
WOZnet
New Zealand
Thanks Guys,
Correct, stability control not turned off. I'll try that on the next run.
Post #1078824 31st Oct 2025 4:23am
