Home > Puma (Tdci) > Hole In block
Page 2 of 2 <12
blackwolf wrote:
I suppose that a hole might have corroded through the block but it is unlikely, and there are many things which could be leaking externally.
I agree, they often can seem like it’s coming from somewhere else as well. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1078587 28th Oct 2025 5:53pm
Harriec
United Kingdom 2009 Defender 110 Puma 2.4 SW Epsom Green
The mechanic that's looked at it thinks that it's rusted through. Seems very strange to me. I've not heard of this happening today block that's 16yrs old?? I can't get a very good picture as it's under the exhaust manifold. I need to remove the turbo and the manifesto see it. I've ordered a cheap flexible camera to see if I can get a better idea before I start taking bits off. So I can put better photos up then. I wonder if I can put a stitch bolt in to plug the hole. But if it has rusted then it could be weak in the whole area.
It would be nice if I could find someone local that would confirm it for me. I'm going to have to remove the bits in the way. And I'm going to have to sort some transport for a while.
(The line in the red circle is coolant leak)
Post #1078617 28th Oct 2025 9:17pm
Head gasket, I think.
Post #1078620 28th Oct 2025 9:51pm
Dinnu
Is that collant Censored out? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1078630 29th Oct 2025 6:37am
revd
engine still runs then a chance it could be repaired once the cause is determined
Post #1078632 29th Oct 2025 7:18am
Harriec
I got a camera down there. You can see the hole with the stream of water coming out ( coolant is all gone so have filled it with water to see the leak).
I'm thinking it's rusted. Do you think it could be 'plugged'?
Post #1078700 29th Oct 2025 4:58pm
jcw
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
May just be the way I’m seeing it but in the first two photos, the hole looks to be almost perfectly round / machined and clean, which would not suggest it’s been caused by rust?
Post #1078702 29th Oct 2025 5:02pm
Mo Murphy
It does look very round !
50 Shades of Pennine Grey
Post #1078703 29th Oct 2025 5:18pm
Harriec
That's a good point. I'm not sure what would cause this. The engine is running absolutely fine.
Post #1078704 29th Oct 2025 5:20pm
Linds Hanson
I would be tempted to try some block sealant in it for now and see if it seals it until you have time to carry out a proper repair.
Post #1078712 29th Oct 2025 6:43pm
Mo Murphy
Do puma engines have a block drain tap like the Tdis ?
Post #1078716 29th Oct 2025 7:13pm
revd
JB weld might just work
Post #1078720 29th Oct 2025 7:45pm
Mo
No.
Post #1078726 29th Oct 2025 9:16pm
Harriec
Ok. Thanks for the help. I was thinking that I could clean the hole up and tap it and put a bolt in (smothered in JB weld) that should block it. But I'm more concerned about why it's happened.....
How easy is the turbo to remove as it's in the way. I would rather not take off the exhaust manifold for obvious reasons. I may just be able to reach with the turbo out of the way?
Post #1078738 29th Oct 2025 10:29pm
Dinnu
Possibly a latent defect - as ling as it can survive the warranty period, its fine.
I would stick some milliput. It adheres very well even to moist surfaces. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1078767 30th Oct 2025 1:33pm
Page 2 of 2 <12
