![]() | Home > Puma (Tdci) > Hole In block |
| Harriec Member Since: 06 Jan 2024 Location: Sussex Posts: 15
Click image to enlarge The mechanic that's looked at it thinks that it's rusted through. Seems very strange to me. I've not heard of this happening today block that's 16yrs old?? I can't get a very good picture as it's under the exhaust manifold. I need to remove the turbo and the manifesto see it. I've ordered a cheap flexible camera to see if I can get a better idea before I start taking bits off. So I can put better photos up then. I wonder if I can put a stitch bolt in to plug the hole. But if it has rusted then it could be weak in the whole area. It would be nice if I could find someone local that would confirm it for me. I'm going to have to remove the bits in the way. And I'm going to have to sort some transport for a while. (The line in the red circle is coolant leak) Click image to enlarge |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18058
Head gasket, I think.
| Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3656
Is that collant
| revd Member Since: 20 Apr 2024 Location: England Posts: 308
engine still runs then a chance it could be repaired once the cause is determined
I got a camera down there. You can see the hole with the stream of water coming out ( coolant is all gone so have filled it with water to see the leak).
I'm thinking it's rusted. Do you think it could be 'plugged'? Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
| jcw Member Since: 11 Sep 2016 Location: Gloucestershire Posts: 179
May just be the way I’m seeing it but in the first two photos, the hole looks to be almost perfectly round / machined and clean, which would not suggest it’s been caused by rust?
| Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2420
It does look very round !
That's a good point. I'm not sure what would cause this. The engine is running absolutely fine.
| Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 540
I would be tempted to try some block sealant in it for now and see if it seals it until you have time to carry out a proper repair.
Do puma engines have a block drain tap like the Tdis ?
JB weld might just work
No. |
Ok. Thanks for the help. I was thinking that I could clean the hole up and tap it and put a bolt in (smothered in JB weld) that should block it. But I'm more concerned about why it's happened.....
How easy is the turbo to remove as it's in the way. I would rather not take off the exhaust manifold for obvious reasons. I may just be able to reach with the turbo out of the way? |
Possibly a latent defect - as ling as it can survive the warranty period, its fine.
I would stick some milliput. It adheres very well even to moist surfaces. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
| All times are GMT |
