Home > Puma (Tdci) > Blanked connector under cubby box??
OrangeAlpine
United Kingdom 2013 Defender 90 Puma 2.2 HT Alpine White
Hi all,
Only had the 90 for a few days (2013 2.2 hard top) so cleaning, tweaking, upgrading and learning (lots) as is go…
I’ve just removed the tatty cubby box ready to replace with a nicer unit and while cleaning it I noticed an unused connector that’s taped down.
Before I start trawling through the electrical diagrams (electrics is my Achilles heel), does anyone know what the standard use is for this?
And while I’m asking, the panel looks in ok condition but is there a need for better waterproofing as removing it is straight through to the open! Great for access to gearbox I’m sure (unlike my discovery 2!) but as I’m new to defenders I thought I ask…
Thanks all Confused
Post #1077340 12th Oct 2025 5:32pm
Clemmo
The panel should have a foam seal around the edge of the underside.
It’s often damaged or twisted.
It’s amazing how much noise a good seal prevents entering the cab.. and as you suggest stops water ingress.
I’m not sure but think the wiring connector may have been for when an Amp was fitted by LR.
They secured them to the back of the cubby box
Thumbs Up
Post #1077348 12th Oct 2025 6:18pm
OrangeAlpine
Thanks @clemmo - Thumbs Up
there was indeed a foam seal and in surprisingly good shape too so I’ll be leaving that one as is!
The connection for amp makes sense. I’ve scoured the electrical library and it didn’t jump out so I’ll with that for now. Will test for voltage when radio is on etc as my plan was to use as a retrofit usb (power) connection in the new cubby
Thanks again
Post #1077349 12th Oct 2025 6:33pm
Martin
Site Admin
Subwoofer  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1077350 12th Oct 2025 6:40pm
OrangeAlpine
@martin - bingo. Thank you sir Bow down
Post #1077352 12th Oct 2025 6:44pm
IIRC there is a plug in active subwoofer for that, if you have the wiring there, it’ll plug straight in.
If you wanted one of course.. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1077357 12th Oct 2025 8:08pm
OrangeAlpine
Thanks. I doubt I’ll use it for a sub - it’s more likely that I’ll work out if it’s possible to run a usb socket from it so I can charge a phone while it’s in the cubby and remove the temptation to be distracted by it!! 😬
Another thing on the list though….
Post #1077358 12th Oct 2025 8:14pm
Will@LRW
 1997 Defender 110 300 Tdi CSW Alpine White
In the interest of trying to improve the documentation, does anyone know the connector number?
The closest I can find is https://www.lrworkshop.com/connectors/defender-2012-2.2tdci/C1354 with similar wiring colours LR Workshop
New parts illustrations https://www.lrworkshop.com/diagrams/land-r...ed-corners
Find a Defender's history and spec: https://defender.lrworkshop.com
Post #1078099 22nd Oct 2025 9:02pm
Martin
Site Admin
C3459
Edit: as per https://www.lrworkshop.com/wiring-diagram/...-subwoofer
and https://www.lrworkshop.com/connectors/defender-2012-2.2tdci/C3459
Wink
The C3459 pinout table is missing pin 1 = PN wire 0.75 CSA  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1078102 22nd Oct 2025 10:02pm
OrangeAlpine
Bow down really useful, thank you all
Post #1078109 23rd Oct 2025 6:07am
Will@LRW
Thanks Martin!
OrangeAlpine do you mind if I use your photo on that linked page? LR Workshop
Post #1078199 23rd Oct 2025 8:19pm
OrangeAlpine
Sure, go for it. Hopefully it’ll help someone else
Post #1078200 23rd Oct 2025 8:23pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
Post #1078326 25th Oct 2025 3:14pm
OrangeAlpine
That’s really useful. Thank you 🙏
Post #1078327 25th Oct 2025 3:21pm
lightning
l have this connector as well.
Can someone post a link to the subwoofer? Probably worth fitting it.
Post #1078369 26th Oct 2025 10:38am
