![]() | Home > Puma (Tdci) > Blanked connector under cubby box?? |
Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1318 ![]() ![]() |
The panel should have a foam seal around the edge of the underside.
It’s often damaged or twisted. It’s amazing how much noise a good seal prevents entering the cab.. and as you suggest stops water ingress. I’m not sure but think the wiring connector may have been for when an Amp was fitted by LR. They secured them to the back of the cubby box ![]() |
OrangeAlpine Member Since: 10 Oct 2025 Location: Winchester Posts: 7 ![]() ![]() ![]() |
Thanks @clemmo -
![]() there was indeed a foam seal and in surprisingly good shape too so I’ll be leaving that one as is! The connection for amp makes sense. I’ve scoured the electrical library and it didn’t jump out so I’ll with that for now. Will test for voltage when radio is on etc as my plan was to use as a retrofit usb (power) connection in the new cubby Thanks again |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6720 ![]() ![]() ![]() |
Subwoofer
@martin - bingo. Thank you sir
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21012 ![]() ![]() |
IIRC there is a plug in active subwoofer for that, if you have the wiring there, it’ll plug straight in.
If you wanted one of course.. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Thanks. I doubt I’ll use it for a sub - it’s more likely that I’ll work out if it’s possible to run a usb socket from it so I can charge a phone while it’s in the cubby and remove the temptation to be distracted by it!! 😬
Another thing on the list though…. |
