![]() | Home > Puma (Tdci) > Problems with Central Locking |
| Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2544
Did the 10AS unit get wet when you “Drowned” your Defender ? You can remove it, open it up and look to see if the relays or other circuitry have any water damage. Also check the loom connectors and the 10AS connectors to ascertain if there is any corrosion.
| HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 824
Hi Ianh,
Luckily, the 10AS is still good and no corrosion. I was considering replacing it with the Remote Key UK version but seeing as my budget was dwindling and that the current 10AS was still in good condition, I opted to defer the acquisition of the Remote Key kit for later. Definitely fancy their all in one FOB and key kit. Will see about the lubricating and cleaning the joints to see if that has an effect. Maybe even make up a longer rod to help keep the locking peg up? Will it make a difference if I flip the actuator around? They seem made to be mounted one way or the other, not upside down, of course |
Lubricating all the locks and mechanisms will help, when I had issues with actuators not locking the doors in winter it was the second row door mechanisms needing a good lube and freeing up.
If your starter battery is low or old and not holding a good charge then that contributes to the issue. You can tell this if the actuators struggle to work with engine off but are fine with engine running. |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21029
Has the cables in the door rubbers been checked for breaks and or continuity?
These are the rubber gaiters between the body and the doors, the cables there can become brittle and break over time. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
