![]() | Home > Puma (Tdci) > 2.4 Puma Stub Axels |
Johan_B Member Since: 20 Sep 2024 Location: Gothenburg Posts: 162 ![]() ![]() ![]() |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 820 ![]() ![]() ![]() |
Thank you, Johan_B!
![]() This helps a lot ![]() |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3646 ![]() ![]() ![]() |
Many, especially those with 2 piece rear halfshafts, prefer not to have any seals in there, so can keep the drive member splines lubed with gear oil. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Hi Dinnu,
I upgraded to one piece drive member & shafts in the rear so maybe not necessary for that? My fronts are Ashcroft bits though so the heavy duty drive member may benefit from the omission of the oil seal as you suggested? Which seal do I omit? Thanks. No Better Friend, No Worse Enemy |
The front axle is a bit different. If you want the axle oil to lubricate the drive member splines you would have to allow oil into the swivel housing, where you today have grease, and then continue out through the stub axle. You would need to omit seal 8 and 23 to make that happen, but I would not advice. Grease the drive members instead.
![]() Click image to enlarge Also, I see no point in changing bearings that hasn't manifested a problem. So I would only change the failed one and leave the other one. |
I would not advise that either. On later axles, you will dilute the grease with final drive oil and vice versa (the former is a bigger problem as it could cause the swivels to leak). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Great to know! Thank you, both!
Just making sure now, when I grease the drive members, they have to be removed, cleaned, greased, then reinstalled? Grease on the drive member and shaft? Or do I just use a needle attachment on the grease gun and try to get as much grease in there without disassembly? No Better Friend, No Worse Enemy |
I just mix lithium grease with EP90 gear oil (approx 50/50) and put inside the drive member cap. I think it works its way in. You only need a very thin film of lubrication. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4340 ![]() ![]() ![]() |
I just put molly CV grease onto the drive member splines, never had any problems with wear. The molybdenum in the grease is specifically for protecting against sliding/fretting wear. 2007 110 TDCi Station Wagon XS
