![]() | Home > Puma (Tdci) > Driving a Puma smoothly |
Jerry Member Since: 13 Nov 2015 Location: Cardiff Posts: 217 ![]() ![]() |
My 2015 puma is very smooth - but I am pretty sympathetic and slow which suits me fine! (I also agree with posts elsewhere that it’s smoother changing at slightly higher revs so that it doesn’t labour in the next gear).
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8450 ![]() ![]() ![]() |
If your lifting rhe clutch and accelerating before the clutch is fully up your just slipping the clutch.
Or the clutch is engaged and the remaining pedal travel is just travel which would suggest switch. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3444 ![]() ![]() |
l just drive normally, like l've always driven. l don't ride the clutch. Changing up through the gears l just balance the rpm and speed like everyone else.
l don't accelerate until the clutch is fully engaged. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17991 ![]() ![]() ![]() |
Oops, my bad. Sorry! I was sure that 2.4 and 2.2 were different. ![]() |
Yes it caught me out when l had my Defender TD5
And will do the same with people who buy one of these switches on Ebay advertised as compatible with "TD5/Puma" Fortunately l tested the switch before l fitted it, and realised the error. |
