Home > Puma (Tdci) > Driving a Puma smoothly
Page 3 of 3 <123
lightning
Lightning, do you know anyone local with a Puma you could drive and who you could let drive yours? Either your vehicle or technique is causing problems and that would be the easiest way to diagnose which.it is.[/quote]
l've driven about thirty altogether over the last three years, most are the same. That is, like mine, need concerted effort to drive smoothly.
A couple were much better, one with under 10,000 miles and another had 117,000 but had a new clutch and output shaft.
Which makes me think, it's possible to make it better.
I've changed the rear DM's and have a clutch switch on order. After that (if it's no better) l'll look at other options such as Alive.
Post #1076822 3rd Oct 2025 6:34pm
Jerry
2015 Defender 110 Puma 2.2 Adventure Phoenix Orange
My 2015 puma is very smooth - but I am pretty sympathetic and slow which suits me fine! (I also agree with posts elsewhere that it’s smoother changing at slightly higher revs so that it doesn’t labour in the next gear).
Post #1076824 3rd Oct 2025 7:09pm
jst
If your lifting rhe clutch and accelerating before the clutch is fully up your just slipping the clutch.
Or the clutch is engaged and the remaining pedal travel is just travel which would suggest switch. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1076837 3rd Oct 2025 10:04pm
lightning
l just drive normally, like l've always driven. l don't ride the clutch. Changing up through the gears l just balance the rpm and speed like everyone else.
l don't accelerate until the clutch is fully engaged.
Post #1076842 3rd Oct 2025 10:51pm
Martin wrote:
Td5 and Puma ones operate in opposite manners. 2.2 Puma and 2.4 Puma are the same.
Oops, my bad. Sorry! I was sure that 2.4 and 2.2 were different. Confused
Post #1076843 3rd Oct 2025 11:26pm
Page 3 of 3 <123
