Page 1393 of 1393 <123 ... 139113921393
rustandoil
Looking very smart there Carman Thumbs Up
Post #1075677 18th Sep 2025 2:25pm
Stacey007
Agree that looks very smart,
I've had mine in bits to fit a better / upgraded screen wash device.. I've now owned this truck 10 years and should have done this 10 years ago..
While I had it in bits I fitted new bulbs for the heater bit of the dashboard, it now all lights up Smile
Fiddly as Shocked with big goofy hands.
Its been neglected a bit lately used for the school runs and general duties, not had a wash for a while so one will be due soon Smile
Post #1075678 18th Sep 2025 2:33pm
Cragster69
Scotland 2007 Defender 110 Puma 2.4 CSW Cairns Blue
Changed the Gearbox oil, the change from 1st to 2nd was feeling notchy.
Thought it might be low on oil, removed the fill plug to see if I could find a level with a (bent over cabletie) dipstick. Oil started pouring out the filler plug.
Drained and refilled with 2.2 Litres of fresh 75W90 GL4 gear oil.
Afte measuring the oil in the drain pan, 3.5 Litres plus the lost drips. Garage that did the service must have topped up to the fill plug.
Feels better now and I think one of the transmission noises is quieter. Craig.
“Don't believe everything you read on the internet.” ― Abraham Lincoln
www.scotgrc.co.uk
Post #1075683 18th Sep 2025 3:12pm
Stacey007 - Who’s washer jet is that, is it Optimil or another?
Cragster69 - Oh yes, over the top fill on the MT82 has those kind of effects.
It’s a fiddle to fill with the precise amount but it’s well worth it to do so, in fact it’s the best way to go.
_________
Today I bought a few bits and pieces from Opie Oils.
Yesterday I fitted part of an upgrade, which I’m pleased with so far. Mr. Green ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1076249 26th Sep 2025 7:10pm
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
Cleaned the maf sensor, then attempted to get to the map sensor to clean that but couldn't undo that damn left hand bolt on the acoustic cover, it just kept spinning!
I recall having issues with that bolt on my old Discovery when trying to put the cover back on, the other two on right hand side were never a problem, what's so weird about that one?! Confused 2004 Defender 90 Td5 CSW
2002 Discovery 2 td5 GS (gone)
1994 Defender 90 300Tdi CSW (gone)
Post #1076298 27th Sep 2025 11:48am
DG123
Revisited the much delayed bush replacement project together with general underneath tidying/painting/dinitrol as there was a spell of dry weather. Whilst I am a seasoned ‘under estimator’ of the time taken for these jobs, I’ve outdone myself here Rolling Eyes
 2012 110 XS SW Orkney Grey
2003 D2 Td5 Black [SOLD]
Post #1076546 30th Sep 2025 11:49am
BrickBox
Pre-winter underside sort out..
Rear wheel bearing rumble, resulted in a full refresh on the rear axle and a chassis treatment. One stuck caliper bolt has slowed progress though. 2017 5.0 V8 Supercharged RRS SVR
2008 2.4 110 Utility Station Wagon XS.
Post #1076570 30th Sep 2025 3:32pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
Gave the old girl new wing mirrors as a quick motorway blast on Sunday night (in between the fog) led to the nearside one going spontaneously into streamlined mode.
Put the design and development engineering adjusters on as well. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #1076597 30th Sep 2025 9:02pm
Cragster69
Following the Gearbox Oil change the gear change was improved but the movement of the lever was a bit crunchy at times.
After a search on here I read about removing the gearstick, cleaning out the old grease and regreasing.
On first refitting it was worse, found this video and rechecked the steps, I had missed the bottom cage.
?si=dRyIrlxGifhrDD4N
Removed and regreased, put it all back together correctly and the gear changes are definitely smoother Craig.
www.scotgrc.co.uk
Post #1076674 1st Oct 2025 8:52pm
