![]() | Home > In Car Electronics > Conclusion: no decent quality single DIN units with CarPlay |
Mr.Jimbo Member Since: 20 Jun 2024 Location: Rugby UK Posts: 32 ![]() ![]() ![]() |
Must it be a single din front size, as I’ve got a fairly good single DIN with a double DIN screen which fits a TD5 style Dash really nicely for 100 quid from Amazon, runs CarPlay the best I’ve had on an aftermarket head unit (my other double din drops out all the time)
Sound quality is OK but it’s a Defender ![]() ![]() Click image to enlarge |
Ridgeway Member Since: 09 Mar 2009 Location: Lausanne Posts: 17 ![]() ![]() ![]() |
Yes that’s a good thought, single DIN base unit with fixed larger screen. Yours actually looks very good from that perspective although i wonder if you know the output power it has or maybe just a link ?
Thanks |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2322 ![]() ![]() ![]() |
What make/model is that please? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20998 ![]() ![]() |
If 1 DIN is an option to you, you might want to consider a Pioneer AVH 7200DAB. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
I wish I’d had commission because every time I post it people want to know how to buy one
![]() Sadly it appears no longer available on Amazon, I found it searching for “single din CarPlay” This was the listing: https://www.amazon.co.uk/dp/B0CF5DS17F?psc...merReviews No affiliation, just pleased with it |
circlethewagons Member Since: 11 May 2024 Location: Brisbane Posts: 28 ![]() ![]() ![]() |
There is this one on Aliexpress (https://www.aliexpress.com/item/1005009566...in_prod%3A
I bought one, it worked OK, the handsfree was rubbish. I have it here if you want it. It ended up being too small for me to see. |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2362 ![]() ![]() ![]() |
I ordered a OD8-CAM003 from aliexpress https://www.aliexpress.com/item/1005007479090100.html in October 2024. The screen was low resolution and it felt a bit grainy/laggy/glitchy in its general operation. It lasted four months and then died.
I ordered another OD8 in March 2025 from a different URL ( https://www.aliexpress.com/item/1005007572754810.html ) The screen is much higher resolution and it is smooth/non-glitchy in its operation. The units clearly have different hardware and/or software, but at face value are "the same" I would not recommend the first OD8 that I bought, but would definitely recommend the second one! > 110 XS Double Cab |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1130 ![]() ![]() ![]() |
There's this looong thread
![]() https://www.defender2.net/forum/topic93497.html So far I'm happy with the cheap unit (display is a bit dark) but I use an external amp twice as expensive as the head unit (a Pioneer, which failed on the first trip - so much for brand quality, replaced it and no failure since). ![]() Click image to enlarge |
rtm89 Member Since: 14 May 2013 Location: North Yorkshire Posts: 261 ![]() ![]() ![]() |
As per this, I'm still using my £33 AliExpress unit every day and it's been great. I have upgraded speakers and it's plenty lound enough in my old rattler!
CdnGriff Member Since: 27 Jul 2025 Location: Ontario Posts: 6 ![]() ![]() ![]() |
Pre-Puma Td5 dash here, the angles for a large screen are ridiculous.
I've been searching for a decent single DIN with floating screen. A lot of cheap stuff like BOSS or Amazon specials. Or super expensive stuff that are beyond my snack bracket. Anyone tried the Sony AVX 8100? It's around $700 CDN (375 GBP) Not expecting the best sound or the best screen, but Carplay and messaging are a must. |
