Home > Puma (Tdci) > Key Fob and immobiliser issue!
Page 2 of 2 <12
Ianh
I’m in Essex so quite a way from you.
A new Nanocom with Puma software , if bought via the group buy on here that gives a 20% discount is circa £360. Not cheap but if you are planning to do work on your vehicle, ie change injectors, power bleed ABS , etc and want to be able to read and Clear Defender specific codes or monitor live data etc while driving then it’s a good tool.
It’s also not locked to a specific VIN so can be used on any Puma defender.
Post #1074716 4th Sep 2025 11:26am
roche1800
Ian
Thanks for your advice and help to date. Yes you are a good distance!
The Nanocom appears to program the Lucas10 (older fob) and ALM (presumably late 2014 and 2015 with chrome strip) fobs. How easy is it?
I have a td5 and 2 Pumas and all I am thinking is at some point another fob is likely to fail …
Post #1074731 4th Sep 2025 4:12pm
Ianh
See the emulator https://emulator.nanocom-diagnostics.com/#
Puma
2.2
Right arrow
ALM
Right arrow
Utility
Plip learn Lear fob type - start
That’s it.
See also https://www.nanocom-diagnostics.com/downloads/preview/alm-ecu. Page 10
Diagnostic Capabilities - (Utility)
Post #1074758 4th Sep 2025 9:18pm
roche1800
Ian
This is so amazingly simple albeit you have given the navigation. Are you a technician?
I am so nearly tempted to go out and buy the Nanacom, just need to do some research …
Thank you
Post #1074763 4th Sep 2025 11:14pm
Ianh
Support for the 2.4 is good , for the 2.2 it initially had issues , I.e injector coding, however over the last 18 months it’s improved and things like injector coding, oil service light reset have become available via software updates.
It also supports the TD5 ( inc fob programming) but you need to purchase a separate license for the Nanocom to support Puma and TD5 vehicle’s.
Post #1074764 5th Sep 2025 12:40am
roche1800
Ian,
Again thank you for the input, your knowledge is quite simply overwhelming. Do you know how much the TD5 license is and when bought is for lifetime on the device. Cheers.
Post #1075002 8th Sep 2025 9:08am
Ianh
See link for pre vat prices, £55.80 to add a TD5 license to an existing Nanocom for a 2.4 / 2.2 Puma.
https://nanocom-diagnostics.com/shop/browse
Have a chat with DieselDriver https://www.defender2.net/forum/member-dieseldriver.html on here re group buy and discounts .
Group buy
https://www.defender2.net/forum/topic65975-495.html
All licences are for life, all software revisions are free, the Nanocom can be used on any defender and is not vin locked to a specific vehicle.
Post #1075031 8th Sep 2025 1:46pm
Page 2 of 2 <12
