![]() | Home > Maintenance & Modifications > Leaks, Leaks everywhere! |
hi Raddy
do a search on the forum for "Water Ingress Manual" ... it's a step by step PDF document ![]() |
Raddy Member Since: 20 Aug 2013 Location: St. Sampsons Posts: 55 ![]() ![]() ![]() |
Ah ah whole manuals worth, got my work cut out then! haha
Thanks for the tip, didn't even notice the search function, makes life easier! |
Andyslandytd5 Member Since: 06 Nov 2021 Location: Southampton Posts: 86 ![]() ![]() ![]() |
So after some heavy rain last night and despite most of the car being under a carport the 110 had some water in the passenger footwell. Not the first time and only happens if the rain is particularly heavy so its been low priority.
I was thinking as one of the actions to minimise this I would try and keep the water from getting in the engine bay near the wing joint to the Bulkhead. I notice on the drivers side there is a little rubber strip to keep water away from the ABS block. Does anyone know the part number of name of this so I can get one to put on the passenger side also? 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present 2004 TD5 90 XS Station Wagon - 2019-2024 2003 TD5 90 G4 LE - 2009-2010 1990 Ninety 6.2 V8 Station Wagon - 2006-2009 |
ChrisDefender Member Since: 29 Oct 2015 Location: Midlands Posts: 476 ![]() ![]() |
Is this the rubber strip you are looking for:
https://maltings4x4store.co.uk/wings-and-a...-+LR038612 Just had to get a replacement one as mine went missing, they do not hold too well without additional help. I struggled to get one any cheaper. |
Yes!, thats the one!. Thanks, Β£32!, pretty steep. I'll have a think 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 886 ![]() ![]() ![]() |
I lashed up something similar to that "seal" from self adhesive draught excluder π
I'll try to get a picture tomorrow |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2308 ![]() ![]() ![]() |
Mine had those strips on, but I also cut a piece of old mudflap and placed/jammed in over the top of the ABS unit. Itβs keep it dry.
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1339 ![]() ![]() ![]() |
I have come to the conclusion that if you like older cars you need a garage (multiple car garage obviously). Apart from protection from weather exposure it also makes working on them much much easier.
I know that this is not much advise to anyone that simply does not have access to a garage, but maybe you can postpone owning a nice classic till you have access to a garage to avoid the frustration. Modern-ish cars are much better standing outside in the rain. |
kyvlle Member Since: 22 Jul 2016 Location: Essex Posts: 78 ![]() ![]() ![]() |
Anyone got a pic of this front wing seal installed? Either factory or a DIY solution.
![]() Here you go, not the best picture but gives you the idea 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present 2004 TD5 90 XS Station Wagon - 2019-2024 2003 TD5 90 G4 LE - 2009-2010 1990 Ninety 6.2 V8 Station Wagon - 2006-2009 |
trevorg Member Since: 28 May 2022 Location: Aisne Posts: 54 ![]() ![]() ![]() |
![]() Click image to enlarge And another. 2012 90SW - 2.2TDCI |
Thanks for sharing!
A useful thread on the same subject
https://www.defender2.net/forum/post890563.html 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present 2004 TD5 90 XS Station Wagon - 2019-2024 2003 TD5 90 G4 LE - 2009-2010 1990 Ninety 6.2 V8 Station Wagon - 2006-2009 |
Here's my self adhesive draught excluder lash-up.... Seems to work but does need renewing, I have some black draught excluder on the bench ready ππΌ
