Home > In Car Electronics > Defender Rear Camera - Mudstuff
Andyslandytd5
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
Hi All, I was having a look at the Mudstuff website earlier and noticed there are 2 new reverse camera options. I was just wondering if anyone had fitted either of them?
I have a Stinger Heigh10 and a aftermarket camera fitted just below the number plate light. Its not the best as seems to pick up glare in the dark but its handy nevertheless.
I saw the 2 options below that look like they'd be pretty good if I were ever to upgrade at some point.
Stinger Camera:
https://www.mudstuff.co.uk/collections/wha...rse-camera
Mudstuff Camera:
https://www.mudstuff.co.uk/collections/wha...rse-camera 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present
2004 TD5 90 XS Station Wagon - 2019-2024
2003 TD5 90 G4 LE - 2009-2010
1990 Ninety 6.2 V8 Station Wagon - 2006-2009
Post #1060989 20th Feb 2025 4:56pm
Andyslandytd5
Finally took the plunge and bought the mud stuff camera recently. Was abit of a faff to fit as instructions were lacking. The part of the loom that connects to the reverse camera is at the head unit end so you need run the power supply from the reverse light forward as well as the camera wire.
But once that was sorted and I started using it it’s great! I had a cheap Chinese camera mounted in the number plate light bracket previously and it was pretty useless. This one is great you can even see if it’s clear when backing around a blind corner. 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present
Post #1073598 18th Aug 2025 2:39pm
Peabod
United Kingdom 2013 Defender 110 Puma 2.2 USW Corris Grey
I’ve also got a cheap camera and have a similar issue with visibility. What’s the view from this camera looks like?
And would you say it’s worth the extra over say a kenwood or alpine unit.
Post #1073659 19th Aug 2025 8:50am
Andyslandytd5
I would definitely recommend it. You cannot see the towbar of course but in every other aspect it’s so much better. 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present
Post #1073702 19th Aug 2025 4:55pm
Peabod
Perfect thanks. Convinced me to get some pennies saved and get this with the stinger head unit.
Post #1073866 21st Aug 2025 4:02pm
Wildcat
United States 1997 Defender 90 V8 Petrol SW Auto Alpine White
Can you use the camera while driving in traffic? Or is it only available while in reverse?
Post #1074076 26th Aug 2025 8:18am
If you set up the video cables correctly and you fit an e brake bypass you can, all of the cameras are quite generic.
Don’t skimp on the video signal cable quality, cheap ones are just that and not sheilded, that’s when you’ll get a poor picture quality regardless of if you have a high spec camera. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1074083 26th Aug 2025 10:27am
Andyslandytd5
I was thinking of wiring up so I could use in traffic. Any ideas on how I would wire it up?
I was wondering if I wired up a second power supply on a switch to the camera and Reverse trigger to activate the camera would that make the reverse light come on too? 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present
Post #1074147 27th Aug 2025 5:24pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
I've not got the Mud one (yet, it may happen if the current one dies). I just ran the power to it from a switch next to the head unit and switch it on when I feel the need. Quite often but not always when reversing and fairly frequently to keep an eye on my little trailer as apart from mini roundabouts it is invisible in all mirrors.
I suspect giving the camera a 2nd power feed would activate the reversing light without some added electronics. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #1074155 27th Aug 2025 6:12pm
Andyslandytd5
I'm thinking of doing the same. I can do basic wiring like installing the camera in the current set up and fitting the Stinger last year. However when I was looking at wiring it to a switch I read you should add a relay?, did you add when on your set up? 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present
Post #1074483 1st Sep 2025 10:52am
300TDi CSW Phil
I didn't put a relay in. They are very low in terms of power consumption so I just put in a 1amp iirc inline fuse. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
M0XQS
Post #1074492 1st Sep 2025 1:40pm
Andyslandytd5
So I did it, I got some nice switches from Mudstuff as I like the factory look. ITs all wired up and working, I installed a double enclosure so I have the option to add a work light later.
Post #1075513 16th Sep 2025 1:50pm
