Home > In Car Electronics > Defender Rear Camera - Mudstuff
Andyslandytd5
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
Hi All, I was having a look at the Mudstuff website earlier and noticed there are 2 new reverse camera options. I was just wondering if anyone had fitted either of them?
I have a Stinger Heigh10 and a aftermarket camera fitted just below the number plate light. Its not the best as seems to pick up glare in the dark but its handy nevertheless.
I saw the 2 options below that look like they'd be pretty good if I were ever to upgrade at some point.
Stinger Camera:
https://www.mudstuff.co.uk/collections/wha...rse-camera
Mudstuff Camera:
https://www.mudstuff.co.uk/collections/wha...rse-camera 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present
2004 TD5 90 XS Station Wagon - 2019-2024
2003 TD5 90 G4 LE - 2009-2010
1990 Ninety 6.2 V8 Station Wagon - 2006-2009
Post #1060989 20th Feb 2025 4:56pm
Andyslandytd5
Finally took the plunge and bought the mud stuff camera recently. Was abit of a chaff to fit as instructions were lacking. The part of the loom that connects to the reverse camera is at the head unit end so you need run the power supply from the reverse light forward as well as the camera wire.
But once that was sorted and I started using it it’s great! I had a cheap Chinese camera mounted in the number plate light bracket previously and it was pretty useless. This one is great you can even see if it’s clear when backing around a blind corner. 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present
Post #1073598 18th Aug 2025 2:39pm
Peabod
United Kingdom 2013 Defender 110 Puma 2.2 USW Corris Grey
I’ve also got a cheap camera and have a similar issue with visibility. What’s the view from this camera looks like?
And would you say it’s worth the extra over say a kenwood or alpine unit.
Post #1073659 19th Aug 2025 8:50am
Andyslandytd5
I would definitely recommend it. You cannot see the towbar of course but in every other aspect it’s so much better. 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present
Post #1073702 19th Aug 2025 4:55pm
Peabod
Perfect thanks. Convinced me to get some pennies saved and get this with the stinger head unit.
Post #1073866 21st Aug 2025 4:02pm
