Home > Technical > Seatbelt Bolt for B-Pillar on Puma Part Number or ID
big110
 2014 Defender 110 Puma 2.2 SW Keswick Green
Hello, in installing an internal cage to the 100, I lost the bolt securing the top on the seatbelt to the B pillar...the top reel located above your shoulder. I read it was a special thread. Does any anyone have a part number for that bolt so I can order a replacement? I cant believe I lost it. Thank you
Post #1073607 18th Aug 2025 5:47pm
rustandoil
Seat belt fixings are usually 7/16 UNF
Post #1073619 18th Aug 2025 7:54pm
big110
Thank you!
Post #1073620 18th Aug 2025 8:10pm
Martin
Site Admin
There's no separate part listed for the bolt, as far as LR are concerned they are "captive" and not supplied on their own from the seat belt assembly.
It is highly likely to be a standard 7/16 UNF seat belt bolt, just getting the right length.
Is it for the "D" or the reel?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1073622 18th Aug 2025 8:17pm
It's not available from LR as an individual part, it is part of the seat belt assembly (so about £200 to replace). As noted above it should be a 7/16" UNF HT setscrew and it should be reasonably easy to replace.
If you've only lost one measure the length off the other.
Edit, post crossed with Martin's.
Post #1073623 18th Aug 2025 8:20pm
big110
This is for the D, I believe. Up above the shoulder towards the top of the B pillar. Any idea the length? Is Grade 8 sufficient?
Post #1073624 18th Aug 2025 8:21pm
big110
blackwolf wrote:
It's not available from LR as an individual part, it is part of the seat belt assembly. As noted above it should be a 7/16" UNF HT setscrew and it should be reasonably easy to replace.
They are both gone... kinda the last bit needed to nip up the 6 point internal cage install ! Devil is in the details as they say!
Post #1073625 18th Aug 2025 8:23pm
Being imperial rather than metric they'd normally be specified using SAE grades, and an SAE grade 5 (equivalent to metric 8.8 ) would be ok and almost certainly what was there originally. SAE grade 8 (equivalent to metric 10.9) would of course also be ok. Don't go lower than SAE 5 or metric 8.8.
They're quite long, perhaps 2", since they have to pass through the belt D and the stand-off swivel. Do a Google image search and you should find a picture e.g. https://rimmerbros.com/Item--i-EVB500820PMA
Post #1073626 18th Aug 2025 8:29pm
big110
Thank you again! I cant see paying 120 dollars for a whole kit when I just need 2 bolts that are maybe 2 dollars a pop! Off to Home Depot I go!
Post #1073627 18th Aug 2025 8:37pm
big110
Thank you Martin and Blackwolf for keeping me on track. Picked up two Grade 8 7/16th UNF (aka fine thread here in canada) and a matching washer. A tad of copper grease on them and they went in like a champ! Thank you so much for saving me headache and 200$ on two kits. Total spent $3.16 USDollars and the diesel it took to get to the store. Cheers mate's!
Post #1073649 19th Aug 2025 12:13am
big110
Bow down
Post #1073650 19th Aug 2025 12:15am
Martin
Site Admin
Excellent!  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1073662 19th Aug 2025 9:24am
Good result, and I am pleased to have been of help.
Incidentally, when did Pinner become a place in Canada? Rolling with laughter
Post #1073685 19th Aug 2025 1:35pm
big110
ahahahah yes I should change that I guess! I still do think of it as home! Rolling with laughter
Post #1073686 19th Aug 2025 1:50pm
Well, I know that London is a city in Ontario, so perhaps Pinner is just outside London.... Laughing
Post #1073690 19th Aug 2025 2:34pm
