Home > Maintenance & Modifications > Anyone fitted air suspension to a Defender?
Page 4 of 5 <12345>
Mo Murphy
The panhard rod goes between the chassis and the front axle, as you change the height, you change the relationship between the two.
50 Shades of Pennine Grey
Post #963258 29th Aug 2022 2:04pm
blackrock
United Kingdom 2012 Defender 110 Puma 2.2 SW Firenze Red
Ah, I suspected something like that. I'll realign the wheelfor the normal driving height.
Post #963261 29th Aug 2022 2:24pm
Raising and lowering the vehicle will have a similar effect to lengthening and shortening the drag link. I would completely expect the straight-ahead wheel position to change by a small amount between extremes.
Post #963284 29th Aug 2022 6:37pm
jimbo55
Andrew, the wheel position will change with the height of the suspension that’s perfectly normal, set the steering wheel straight in which ever setting you drive most on the road. For me I drive most in sport which is 1”lowered and set it to that so when I go to off-road or normal the wheel does move out of centre slightly
Post #963293 29th Aug 2022 7:22pm
blackrock
Thanks for the replies, I was beginning to think that I'd somehow put the steering wheel on wonky a few weeks back. I also use the slightly lower setting for normal driving so I'll set the wheel straight on that setting.
Andrew
Post #963302 29th Aug 2022 8:44pm
blackrock
jimbo55 wrote:
Yes I have a VB kit, I do find the lights on the controller a bit too bright so always have the controller face down to stop any glare on the windscreen
I've just been reading the VB user manual and apparently you can adjust the brightness of the LEDs on the controls. A short press of the service button with the spanner on it, followed by the up and down arrows that should adjust the brightness of the LEDs.
I'll try this next time I'm in the vehicle.
Andrew
Post #965381 18th Sep 2022 12:17pm
MercianRover
United Kingdom 1998 Defender 110 300 Tdi CSW Java Black
blackrock wrote:
As a mad idea I was wondering if I could build some electric spring compressors that compress all four springs on command. All I'm after is a temporary lowering of the vehicle, I'm not after the smoother ride that is advertised (a lot). Presumably the bumps stops are reachable with a compressor, as they must be reached at times. I'm not sure it would bother the springs too much, maybe they wouldn't like being compressed repeatedly, and the mechanics would be interesting to say the least.
Andrew
In the US rock crawlers sometimes have "suck-down" winches to pull the axle into a full (or near-as) bump condition to improve stability on climbs and descents.
Post #965484 20th Sep 2022 8:15am
jst
We used our rear winch as a suck down winch for Croatia trophy terrain at times.
Anyone fitted irb suspension, or had it fitted? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1034776 14th May 2024 8:36pm
jst
Did you have any pics of the vb kit install they did in Tiverton please. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1057504 15th Jan 2025 11:31pm
jst
blackrock wrote:
I've booked in for a VB Air suspension to be fitted. I was going to do it myself, but it turns out to not be hugely cheaper, even the inexpensive kits are pretty expensive. The reason for the VB Air kit was firstly that it looks like a well made kit, and secondly it lists one of the lowest travel, down to the bump stops. Some other kits list -60mm, I'm not sure why, the VB (and one or two others) list -110mm max and -100mm as the lowest workable height. I measured the bump stops and I think the -110mm is to the bump stop. These measurements are all at the rear, which on a 110 is my problem height.
I'm wondering if the kits that only go 60mm lower are restricted by the air springs not being able to compress that far?
We'll see how it goes...
Who did you book in with? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1073131 11th Aug 2025 7:18am
jst
Is anyone on here running rear air only. Pure air that is, not coil with air
Am looking for options on 130 for load levelling ability.
Currently coil with air helper rear just wondering if comfort gains are sufficient to warrant air only.
Also considering air alround but have concerns over front shock bottom mount and axle brackets for axles within weld range issue. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1073146 11th Aug 2025 9:34am
TexasRover
The D2 has rear air only and when I had one the main benefit I found was that it level's the suspension, obviously you vary the spring rate meaning it's not bouncy empty or wallowing full.
Was a simple system that people used to replace with an even simpler system: springs. Wonder how easy to retrofit that on a defender. Did not read the whole thread - apologize if I state the obvious.
Post #1073152 11th Aug 2025 10:04am
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
I have D2 on air and also 130. Air on D2 works nice, especially for leveling the car, but for a bit heavier 130 I think the D2 airbags are a bit weak. Sourcing the right airbags is the biggest problem for me - not just buying them once, but beeing able tu buy them again later. On our too heavy D2 airbag live is 8 years, with standard D2 it was a like 10-12 year. During out prips, I have spare airbags, because we had them exploded before.
Mechanical part is "esay", you need to do it once. Pneumatics can be overcome with some manual valves, it something goes wrong, but with "exploded" airbag there is no good solution to move the car.
To be fair, I have seen also broken coil springs. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1073156 11th Aug 2025 12:43pm
Def90
United Kingdom 2015 Defender 90 Puma 2.2 SW Corris Grey
Hi
If you are looking for Air Bags to fit a Defender then have a look at the 1992 -1994 Rang Rover Classic with EAS, only issue good units are not easy to find.
The Air Springs are a direct fit onto a Defender axles front and rear but will need a 10mm spacer plate between the top of the Air spring and the chassis mounts, so air spring clears the the underside of the chassis spring mounting plate.
The other plus with these air springs is they appear to be the correct length and spring rate / loading for a 90 or 110, not sure how they would hold up on a full loaded 130!
I also agree with air springs needing replacing after a few years on a D2, but put them on the list of service items
Post #1073172 11th Aug 2025 2:46pm
jst
Cheers guys.
How are you controlling them, filling them? Fill once and leave for any given load or do they constant adjust?
Cross linked to each other to help air conservation on cross axles? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1073174 11th Aug 2025 3:15pm
Page 4 of 5 <12345>
