Home > Maintenance & Modifications > Anyone fitted air suspension to a Defender?
Page 5 of 5 <12345
Def90
United Kingdom 2015 Defender 90 Puma 2.2 SW Corris Grey
Hi
I do intend to run them with an air management system as I wanted the air system to get into a garage but just haven’t got around to it.
At the moment they are all stand alone air lines with schrader valves and just work like individual springs.
I set them up to a standard ride hight for a 90 with a full tank of fuel and occasionally need to top them up but apart from that they work fine not as harsh as standard springs ,I wouldn’t open cross link them for road use.
Post #1073179 11th Aug 2025 3:54pm
TexasRover
I think at the front you would need to relocate the damper since on a Defender this goes through the center of the spring, while on a RRC air suspension it obviously cannot. You could swap the axle (?) but you would still need to create a top mount. On the back you might get a straight swap agreed.
For controls, unless you just fit some schrader valves at a strategic location and inflate and forget, you could consider using the RRC/P38 controller. It has a bad rap for sure, but it is a stand alone system, pretty simple and still very serviceable.
I have a P38 and worked through the whole suspension system and it has never caused me any issues once I sorted the valve block with a new seal kit (dropping) and fixed the compressor electrical supply relay and plug (occasional error code). Parts are cheap too but the solid axles will never provide the same smooth ride as independent like my Discovery 4. I like to keep my P38 original, but I don't think the ride would deteriorate much if you were to put it on coils, which many people do.
Post #1073180 11th Aug 2025 3:57pm
Def90
Hi TexasRover
If you look at the picture of my front air spring I am running the the RRC damper mounting turret with an additional bracket on the axle that works fine.
I looked at using the original RRC control system but now considering a much simpler AccuAir system.
Post #1073181 11th Aug 2025 4:06pm
MadTom
Controll system, at least basic with just manual controll is a must - to lower the car for parking/low gates, level the car during camping on uneven terrain and to inflate/deflate according to load in the vehicle.
In our D2 the difference of unloaded/fully loaded vehicle is more than 500kg, in Defender is can be much more. D2 drops at least 5cm during loading, and it automatically rises when started. 1cm height difference is nearly invissible, but 5cm is too much. Most impostant function of ait suspension is the self leveling.
Crosslink - I think, the tubes used to connect the bags are too small for any fast air movement between airbags. D2 uses tube with 4mm OD and 2mm ID - very thin. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1073200 12th Aug 2025 6:12am
jst
Currently considering just rear system from On Air or the airbag man full system. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1073632 18th Aug 2025 9:03pm
Page 5 of 5 <12345
