![]() | Home > In Car Electronics (L663) > Pivi Pro playing up, no sound. |
| Down & Dirty Member Since: 15 Sep 2023 Location: Somewhere outback Posts: 115
Can you not reset privi by holding down Center of volume button for about 20 seconds 🤔 26MY SE 90 in Woolstone green on order.
24MY HSE X-Dynamic 90 Carpathian Grey |
| billy2shots Member Since: 23 Oct 2024 Location: England Posts: 46
Holding that down does nothing.
| Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2789
Are you doing it while stationary and in park, but with the engine running?
And also holding it down long enough? 26MY SE 90 in Woolstone green on order.
| Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2791
Happened to me a few times over the years... normally sorts itself out after the car goes to sleep (leave it locked for 30+mins I think)
but disconnecting the battery for a moment also does the trick (tip: enable service mode on the remote app so they don't think it's been stolen) Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
| ruben Member Since: 04 Feb 2021 Location: ASTURIAS Posts: 385
Before disconnecting the battery, with the subsequent danger to the car, I would remove and after place again the blue fuse 51 from the trunk fuse box....and if it doesn't work any other related one from the list that appears in the user manual!
good luck! ExDiscovery 3 TDV6 SE |
| Colin68 Member Since: 18 Jul 2024 Location: Blackpool Posts: 128
Ha ha i know what you mean. I disconnected the battery to fit new steering wheel and within 30 seconds Land Rover were on the phone! at least it shows its working! |
| scottbraun5 Member Since: 08 Jul 2025 Location: Wisconsin Posts: 2
I had a separate issue where I had to replace the amp for the fuse. Where do we find a fuse map for the other bigger fuses in the loadspace fusebox? FL13? I think it is covers the amp. When this fuse is removed, pivi produces no sound, no even from a blinker. The volume knob does not work. You may want to try resetting the amp by removing the fuse FL13-FL16, I don't recall the #, there is only one there. And use that remove/replace to reset it.
| fola Member Since: 22 Jun 2025 Location: BB Posts: 1
You are not alone. wierdly, the phone connects but calls are muted, no radio.... Happened to me three times so far, the car is 3 weeks old. Only "time" fixes the issue. a real PITA. |
| JDPRRUK Member Since: 26 Nov 2024 Location: West Yorkshire Posts: 6
To reset I think you need to hold down telephone button for 25 seconds (car must be in Park). Works on my MY24 RRS
| mse Member Since: 06 Apr 2008 Location: UK Posts: 5117
Mines playing up and does it from time to time including the last few days
The pivi rest usually fixes it but doesnt I never know whether its a sim/software car issue or a server issue JLR side. You can see if the cars got an active connection in the settings. Mike |
| fcaselli Member Since: 20 Jul 2025 Location: Lisbon Posts: 1
I have the car for one month and it happened to me twice.
Holding down the volume button for 20secs sorted it. But it is very annoying. |
| All times are GMT |
