Home > Modifications & Maintenance (L663) > Retrofit 11.4 Pivi Display
Page 13 of 14 <123 ... 121314>
Darrant1234
I’m interested in doing this to replace my 10 inch screen but getting the place holder images would annoy me. Has this been resolved now? Do I still need to get a used screen to be sure this won’t be an issue or is it ok on the new aliexpress screens.
As for 3 rows on apple play, there was an iOS update other day with a car play update which mentioned 3 rows now. Version 18.4
Post #1064707 4th Apr 2025 11:51pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
You don't get the placeholder fault with the Chinese screen and no missing graphics eg the car missing on wade assist.
Thanks for the info on carplay, that would explain it as I just updated my phone to 18.4 Bow down Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1064708 4th Apr 2025 11:54pm
Darrant1234
So with gap tool I should be ok. What screen did you get and did it come with a bracket. I’ve seen the powerful uk ones
Post #1064709 5th Apr 2025 12:09am
Hairy Dan
This is the screen that I bought, it comes with everything you need, screen and bracket and then I enabled it with my IID G4 tool
https://www.aliexpress.com/item/1005007504...18022EIAtN Cheers Ian
Kielder 4x4 Safari
Post #1064710 5th Apr 2025 12:13am
Darrant1234
Thanks for the link. Looks to be a 13 inch screen not sure if I want 13 or the 11.
Post #1064711 5th Apr 2025 12:41am
Temicxoch
Canada
Thanks to everyone for this informative thread!
Ian, how did you end up choosing this particular screen from the two options you linked to in your previous post? I'm only asking because the other option (#2) is currently much cheaper:
https://www.aliexpress.com/item/1005007475...pt=glo2nld
Cheers!
David
Post #1067323 9th May 2025 12:47am
LostCause
Canada
I seen the same thing when I ordered but the mounting is the same and the bracket is for the new screen. So no difference. I ordered the update from the 10" but the package comes with the bracket to go directly to the 13". It also included two additional side pieces if you are coming from the 11" as the rear of the original screen mount is smaller than the 10".
Go back in the thread and look at my pictures you will see the contents of the order I received. you will see the bracket to go directly to the 13 and then some side pieces for the 11" conversion. In my case i did not need them.
Post #1067369 9th May 2025 3:38pm
Hairy Dan
Cheers!
David
I ended up going for the more expensive one as the seller gave me a voucher to match the cheaper price and I wanted to go with the seller that others had recommended, just looking at those the price has gone up hugely since I bought Shocked Cheers Ian
Kielder 4x4 Safari
Post #1067419 9th May 2025 11:55pm
Temicxoch
Canada
Thanks for the responses. Maybe I’ll watch the listing for a while to see if it goes on sale. I’ll post an update if I end up going forward with the install!
Post #1067497 11th May 2025 6:28pm
Temicxoch
Canada
Just following up to say that I purchased the 13 inch screen when it went on sale and installed it today. Everything went smoothly and it is working perfectly. Thanks again to everyone who contributed to this thread! Cheers, David
Post #1069331 8th Jun 2025 11:29pm
c4skp
Clark4x4 wrote:
So... 13.1 upgrade DONE!!!
but, I used a USED Range Rover Sport screen, so not brand new, I guest has coded for Range Rover Sport...
and is a "destructive" method... you need to cut some trims, at lease to install in the way I prefer, there is a kit (powerfull) to do it in not destructive way Laughing
so first test used screen is working. IMPORTANT, need to add the 2 adittional power wires (PINS 6 and 7):
connect, change CCF, multican 641, couple of reboots and voila:
after check everything is working, all images are good, defender model, not RRS!!!... then to finish installation, enter in destructive way... we need to adapt one plastic piece first:
cut some space for connectors (in orange) and made new holes to use plastic trim from 11.4 in 13.1 screen: (yes, I do 2 more than I needed.. I take wrong lenght)
I need to check lenghts several times, (the idea is keep same bottom position, I add 2 mm to get more space) but at the end I got plastic trim as I wanted (yes, I do 2 more than I needed.. I take wrong lenght):
Ok, now I can install screen. but upper trim need some work.... more or less you need to remove this area:
I user a multy tool, first separate the fabric from plastic, and use a piece of metal to avoid cutting fabric, so at the end:
put upper trimm and that's all!!!
If some of you are interested in my previous 11,4 screen... check for sale area Whistle
Cheers!!!
Hi, thanks for the info on the 11 to 13", its what im looking to do on my model.
Did you have the 11" from factory, so the lower rail had the indent?
Would you be able to take some pictures side on?
Have a couple of 13" from accident cars.
Thanks
Post #1069963 18th Jun 2025 12:15pm
Clark4x4
Spain
well, I have originally 10' screen, then updated to 11.4 with original parts, and finally to 13 inch screen from a Range Rover Sport.
I made indent in upper rail and adapt to put screen to my own opinion... you could see on images is maybe little upper than MY26.
By the way, maybe upper trim and pieces from MY26 could be used now that I think about it...
Sorry, don't have additional pictures...
Regards
Post #1070249 24th Jun 2025 4:03pm
Manuto
Canada
I have the same issue as you on my MY21 model using the aliexpress 13" screen upgrade.
I can get rid of the placeholder message by changing the CCF on EUCD-229 Model Year
 to anything above "2021 3/4" (when the larger touch screen was introduced) but that creates the emergency breaking fault.
I had to revert EUCD-229 Model Year
2021. Still looking for a fix
The same issue was flagged @mikesdnielsen
Post #1070619 1st Jul 2025 7:11am
Manuto
Canada
Also for anyone interested here is what the iOS CarPlay 26 looks like on the 13” AliExpress display.
The first photo is the default layout and the second one shows the new adaptive zoom showing smaller icons and text.
I keep trying back and forth between those 2 settings.
Post #1070724 3rd Jul 2025 1:38am
mmbanf
Italy
great job, very nice 13 screen!
how did you enable the icons on the left of the monitor?
i tried to modify ccf with gap, but it doesn't work.
Marco
Post #1070818 4th Jul 2025 8:13am
