![]() | Home > Modifications & Maintenance (L663) > Retrofit 11.4 Pivi Display |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1448 ![]() ![]() ![]() |
You don't get the placeholder fault with the Chinese screen and no missing graphics eg the car missing on wade assist.
Thanks for the info on carplay, that would explain it as I just updated my phone to 18.4 ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Darrant1234 Member Since: 03 Nov 2024 Location: Wakefield Posts: 24 ![]() ![]() |
So with gap tool I should be ok. What screen did you get and did it come with a bracket. I’ve seen the powerful uk ones
This is the screen that I bought, it comes with everything you need, screen and bracket and then I enabled it with my IID G4 tool
https://www.aliexpress.com/item/1005007504...18022EIAtN Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Thanks for the link. Looks to be a 13 inch screen not sure if I want 13 or the 11.
Temicxoch Member Since: 09 May 2025 Location: Rockwood Posts: 4 ![]() ![]() |
Thanks to everyone for this informative thread! Ian, how did you end up choosing this particular screen from the two options you linked to in your previous post? I'm only asking because the other option (#2) is currently much cheaper: https://www.aliexpress.com/item/1005007475...pt=glo2nld Cheers! David |
LostCause Member Since: 07 Jan 2025 Location: Toronto Posts: 12 ![]() ![]() |
I seen the same thing when I ordered but the mounting is the same and the bracket is for the new screen. So no difference. I ordered the update from the 10" but the package comes with the bracket to go directly to the 13". It also included two additional side pieces if you are coming from the 11" as the rear of the original screen mount is smaller than the 10".
Go back in the thread and look at my pictures you will see the contents of the order I received. you will see the bracket to go directly to the 13 and then some side pieces for the 11" conversion. In my case i did not need them. |
I ended up going for the more expensive one as the seller gave me a voucher to match the cheaper price and I wanted to go with the seller that others had recommended, just looking at those the price has gone up hugely since I bought ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Thanks for the responses. Maybe I’ll watch the listing for a while to see if it goes on sale. I’ll post an update if I end up going forward with the install!
Just following up to say that I purchased the 13 inch screen when it went on sale and installed it today. Everything went smoothly and it is working perfectly. Thanks again to everyone who contributed to this thread! Cheers, David
c4skp Member Since: 11 Oct 2020 Location: Dorset Posts: 25 ![]() ![]() |
Hi, thanks for the info on the 11 to 13", its what im looking to do on my model. Did you have the 11" from factory, so the lower rail had the indent? Would you be able to take some pictures side on? Have a couple of 13" from accident cars. Thanks |
Clark4x4 Member Since: 19 Jun 2023 Location: Madrid Posts: 39 ![]() ![]() |
well, I have originally 10' screen, then updated to 11.4 with original parts, and finally to 13 inch screen from a Range Rover Sport.
I made indent in upper rail and adapt to put screen to my own opinion... you could see on images is maybe little upper than MY26. By the way, maybe upper trim and pieces from MY26 could be used now that I think about it... Sorry, don't have additional pictures... Regards |
Manuto Member Since: 27 Jan 2021 Location: Vancouver Posts: 22 ![]() ![]() |
I have the same issue as you on my MY21 model using the aliexpress 13" screen upgrade. I can get rid of the placeholder message by changing the CCF on EUCD-229 Model Year to anything above "2021 3/4" (when the larger touch screen was introduced) but that creates the emergency breaking fault. I had to revert EUCD-229 Model Year 2021. Still looking for a fix ![]() Click image to enlarge The same issue was flagged @mikesdnielsen Last edited by Manuto on 3rd Jul 2025 1:41am. Edited 1 time in total |
![]() Click image to enlarge Also for anyone interested here is what the iOS CarPlay 26 looks like on the 13” AliExpress display. The first photo is the default layout and the second one shows the new adaptive zoom showing smaller icons and text. I keep trying back and forth between those 2 settings. ![]() Click image to enlarge |
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 184 ![]() ![]() |
great job, very nice 13 screen!
how did you enable the icons on the left of the monitor? i tried to modify ccf with gap, but it doesn't work. Marco |
