Home > Modifications & Maintenance (L663) > Retrofit 11.4 Pivi Display
Page 13 of 13 <123 ... 111213
Darrant1234
I’m interested in doing this to replace my 10 inch screen but getting the place holder images would annoy me. Has this been resolved now? Do I still need to get a used screen to be sure this won’t be an issue or is it ok on the new aliexpress screens.
As for 3 rows on apple play, there was an iOS update other day with a car play update which mentioned 3 rows now. Version 18.4
Post #1064707 4th Apr 2025 11:51pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
You don't get the placeholder fault with the Chinese screen and no missing graphics eg the car missing on wade assist.
Thanks for the info on carplay, that would explain it as I just updated my phone to 18.4 Bow down Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1064708 4th Apr 2025 11:54pm
Darrant1234
So with gap tool I should be ok. What screen did you get and did it come with a bracket. I’ve seen the powerful uk ones
Post #1064709 5th Apr 2025 12:09am
Hairy Dan
This is the screen that I bought, it comes with everything you need, screen and bracket and then I enabled it with my IID G4 tool
https://www.aliexpress.com/item/1005007504...18022EIAtN Cheers Ian
Kielder 4x4 Safari
Post #1064710 5th Apr 2025 12:13am
Darrant1234
Thanks for the link. Looks to be a 13 inch screen not sure if I want 13 or the 11.
Post #1064711 5th Apr 2025 12:41am
Temicxoch
Canada
Thanks to everyone for this informative thread!
Ian, how did you end up choosing this particular screen from the two options you linked to in your previous post? I'm only asking because the other option (#2) is currently much cheaper:
https://www.aliexpress.com/item/1005007475...pt=glo2nld
Cheers!
David
Post #1067323 9th May 2025 12:47am
LostCause
Canada
I seen the same thing when I ordered but the mounting is the same and the bracket is for the new screen. So no difference. I ordered the update from the 10" but the package comes with the bracket to go directly to the 13". It also included two additional side pieces if you are coming from the 11" as the rear of the original screen mount is smaller than the 10".
Go back in the thread and look at my pictures you will see the contents of the order I received. you will see the bracket to go directly to the 13 and then some side pieces for the 11" conversion. In my case i did not need them.
Post #1067369 9th May 2025 3:38pm
Hairy Dan
Cheers!
David
I ended up going for the more expensive one as the seller gave me a voucher to match the cheaper price and I wanted to go with the seller that others had recommended, just looking at those the price has gone up hugely since I bought Shocked Cheers Ian
Kielder 4x4 Safari
Post #1067419 9th May 2025 11:55pm
Temicxoch
Canada
Thanks for the responses. Maybe I’ll watch the listing for a while to see if it goes on sale. I’ll post an update if I end up going forward with the install!
Post #1067497 11th May 2025 6:28pm
Temicxoch
Canada
Just following up to say that I purchased the 13 inch screen when it went on sale and installed it today. Everything went smoothly and it is working perfectly. Thanks again to everyone who contributed to this thread! Cheers, David
Post #1069331 8th Jun 2025 11:29pm
