Home > Technical > Help! - No start
bear100
Help! - No start
Please help! Stuck is Hopwood services! Stopped for a coffee on the way to billing office road show,jumped back in ignition on and turned the key. Start engine- nothing. No click, no sound any suggestions?! 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #1070407 27th Jun 2025 11:11am
excossack
Wire fallen off the solenoid the for the starter? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1070408 27th Jun 2025 11:16am
Martin
Site Admin
Cluster not passing through immobiliser signal?
Give the top of the cluster a thump.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1070409 27th Jun 2025 11:23am
Ianh
Did you open and close one of the second row doors ?
Check your 10AS fuses, one may have blown due to a short on the B pillar central locking loom.
Two in under seat fuse box, one in under dash fuse box.
https://www.lrworkshop.com/electrics/defen...nd-headers
Post #1070410 27th Jun 2025 11:33am
bear100
Managed to bump start so we’re up and running. Looks like I’ve got an issue with the starter motor. Solenoid is clicking but no attempt to spin on the start. Back on route to billing off road show any kind souls see a black 110 with an Ozpod setup. Give us a hand for beer tokens! 👍 2023 Defender L663 V8
Post #1070413 27th Jun 2025 11:40am
Ianh
Did you change your main relay after the issue you posted in another topic recently?
Post #1070414 27th Jun 2025 11:44am
johnlad
I don’t mind lending a hand if you need it. Not brilliant on electrical stuff but have a basic socket set with me.
Post #1070422 27th Jun 2025 2:18pm
bear100
Cheers Johnlad!
Ianh ordered one online but didn't turn up in time, I think this is a different fault?
This time the dash performed as it should needles and lights as they should be, just nothing when it’s turned for the starter to engage, swapped relays (main and starter) the same. I could feel the starter relay clicking too. Bumped it luckily and made it to Billing show. Turned engine off and it restarted perfectly fine every time??? 2023 Defender L663 V8
Post #1070424 27th Jun 2025 2:24pm
johnlad
Sounds like a connection issue or battery maybe weak
Post #1070426 27th Jun 2025 2:35pm
excossack
Sticking starter solenoid ? Might find a rebuild kit at Billing. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1070427 27th Jun 2025 2:35pm
bear100
Battery all good - twin optima’s fully charged, terminals tight and secure.
I know the ignition switch is good because the starter relay was clicking, still could be the relay I suppose? Or the solenoid?
Tried again this morning and it starts with no issue Rolling Eyes
The starter look a pig to do, anyone done it on the drive? 2023 Defender L663 V8
Post #1070469 28th Jun 2025 8:04am
johnlad
If it’s a td5 then the top bolt requires a selection of extensions to get a socket on it. Once that’s out the other 2 are straightforward
Post #1070473 28th Jun 2025 8:32am
landy andy
I believe it’s a 2.4 Tdci 👍🏻
Post #1070477 28th Jun 2025 10:03am
johnlad
I skipped a generation there so I’ll be no use on this repair
Post #1070499 28th Jun 2025 3:40pm
bear100
Worked perfectly fine all weekend and this morning,…
Just got back from the 3 hour drive from Billing left it sit for a while why emptied some of the camping gear. Tried to start and……nothing.
A bit more time and on the drive I’ve used a long screw driver on the starter and can hear a faint clunk, went underneath and tapped the starter solenoid end a few times, turned the key and it started!
So a sticking starter solenoid when it’s hot!
So what’s best approach? New starter? New solenoid kit? Both these DIY jobs on a drive? Or best get the mech involved? 2023 Defender L663 V8
Post #1070550 29th Jun 2025 2:21pm
