Home > Technical > Help! - No start
Page 2 of 2 <12
jst
If original starter on a 2010 I would change it rather than just changing the relay.
Yes doable on driveway. Small hands help Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1070551 29th Jun 2025 3:13pm
bear100
I thought the same makes sense really, yep it’s the original unit.
I’ve got hands like shovels Shocked 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #1070552 29th Jun 2025 3:16pm
ickle
PITA to do - but doable!
Watch for the hollow dowels that the bolts go through (IIRC) sometimes they stick in the casting, sometimes in the motor. I drained the coolant and pulled off some hoses for access, but mines a LHD with a/c so more rubbish to contend with.
Also starter bolts to the side of the box, bolts are at 90 degrees to the axis of the motor, just a bit counter intuitive for me as all the others I can remember doing bolts are in line with the motor...
I also did all of the connections with the motor loose and then a final check when it was firmly installed.
HTH Keith
Post #1070553 29th Jun 2025 3:42pm
Page 2 of 2 <12
