Home > Puma (Tdci) > Coolant bubbles
Page 2 of 3 <123>
SilverPuma
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Parts list would be great thank you. Did you replace chain while at it? 2010 2.4 TDCI Puma Defender 90
Post #1069542 11th Jun 2025 8:54pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
Timing chain, gears, guides and tensioner kits are inexpensive. So, yes, change it all while you are in there.
Post #1069543 11th Jun 2025 9:01pm
SilverPuma
Tested on running hot engine, pumped for over 2 minutes. No obvious reaction, will check out some other causes as well….. 2010 2.4 TDCI Puma Defender 90
Post #1069594 12th Jun 2025 7:02pm
bear100
That has stayed very blue! Did you go for a good run? Mine was the same unless it went on at least a 2 hour run in the beginning, it did get worse over a few months. Fingers crossed it’s not the head for you.
List of what I used to do my head
New complete head from turner engineering
New head bolt set
New head gasket 3 hole
New head gasket seal kit
New Elring copper injector rings
New stretch bolts
New timing cover
Permatex grey
Permatex black
Assembly lube
New drive belt 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #1069597 12th Jun 2025 7:53pm
MK
So, were the bubbles coming up while you ran the test?
 Puma 110" SW
Post #1069634 13th Jun 2025 2:28pm
SilverPuma
Ran test again and waited a bit longer……
Have gone the route suggested by Bear now and ordered all the parts plus timing chain kit. Only thing not ordered is the head gasket as I assume I need to be 100% that it’s never been skimmed etc for gasket thickness?
In the interests of do it once do it well what’s the best gasket make? Thanks 👍🏻 2010 2.4 TDCI Puma Defender 90
Post #1069650 13th Jun 2025 5:13pm
jbcollier
Both Bear100's and my heads past a machine shop pressure test but combustion gases were still leaking in use, albeit very, very slowly. I think that people should just fit a new head after 15+ years of use, no ifs, and/or, buts about it.
The head gasket thickness is based on piston protrusion. That does not change when the head is shaved. Just match the old gasket unless you also change pistons.
Post #1069657 13th Jun 2025 6:08pm
jbcollier
PS: If you look carefully with a flashlight, you can see what gasket is in there without having to disassemble it.
Post #1069658 13th Jun 2025 6:09pm
SilverPuma
I assume you moved the camshaft’s across to the new head? No parts needed hopefully? 2010 2.4 TDCI Puma Defender 90
Post #1069671 13th Jun 2025 8:30pm
BrickBox
Should just be a bare new head and use your cams/valves etc - but cleaned and re-lapped. 2017 5.0 V8 Supercharged RRS SVR
2008 2.4 110 Utility Station Wagon XS.
Post #1069672 13th Jun 2025 8:43pm
jbcollier
Turner sells a head complete with valves, springs, retainers and seals.
Lapping valves is generally frowned upon in these days of CNC valve machining.
Post #1069675 13th Jun 2025 8:58pm
BrickBox
I’ve just had a look myself- I didn’t realise that was an option. Actually not a bad price for a new head.
Link for anyone interested:
https://www.turnerengineering.co.uk/produc...es-springs 2017 5.0 V8 Supercharged RRS SVR
Post #1069683 13th Jun 2025 10:42pm
bear100
its a pretty good price, well packaged and the head is a good quality item.
just to the right hand side front you can see the head gasket which will have 1-3 holes which denotes the thickness of the gasket, Turners will sell you an Elring which is really good quality.
i bought a timing pin kit but you can use drill bits, it makes no difference, i also bought a tool for the timing cover seal, the tool wasn't a very good fit tbh and found using 2 alan keys and a screwdriver to twist it off and on was just as easy.
plenty of light, plenty of gloves, plenty of tea, music on....its not so bad
good luck 2023 Defender L663 V8
Post #1069687 14th Jun 2025 6:58am
Siwynne
You don’t need to remove the inlet or exhaust manifolds completely. Release them from the head and pull them back. There is enough flexibility to this if the egr is disconnected. This means the turbo can stay completely connected. It turns it into a 1 day job rather than two if I do it this way
Post #1069690 14th Jun 2025 7:54am
SilverPuma
So……
All parts arrived, just head gasket to go. Would you say this is a two tooth gasket or could there be a third hole further along that can’t be seen?
Post #1069971 18th Jun 2025 4:21pm
Page 2 of 3 <123>
