Home > Puma (Tdci) > Coolant bubbles
Page 3 of 3 <123
MK
Definitely 2 holes. A 3rd hole would be located closer to the edge of the gasket. Puma 110" SW
Post #1069972 18th Jun 2025 4:30pm
SilverPuma
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Perfect, thanks 2010 2.4 TDCI Puma Defender 90
Post #1069973 18th Jun 2025 4:38pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
That's a two (2) for sure.
Post #1069980 18th Jun 2025 6:00pm
Johan_B
Sweden 2007 Defender 110 Puma 2.4 CSW Tonga Green
That should be a two hole gasket. Mine looks the same.
Post #1069984 18th Jun 2025 6:56pm
HardCharger
As some of you remember, I was having coolant issues as well. The leak was due to an old hose that split but couldn't be seen when everything is installed.
As for my coolant eruption, we later found out my cylinder head had a crack on number 2. This resulted in coolant loss and pressurization to cause the eruptions plus, it clogged some of my oil galleries to the point that, for example if the oil passage is 1.5 mm, only 0.5mm was left for oil to pass. So a thorough cleaning was in order.
Good thing I was already rebuilding my engine anyways so I went and changed whatever needed to be changed and upgraded what I could.
My 110 is 2011 2.4 Puma, by the way. I also had a 2 toothed cylinder head gasket. No Better Friend, No Worse Enemy
Post #1070003 19th Jun 2025 1:50am
Page 3 of 3 <123
