![]() | Home > Modifications & Maintenance (L663) > Maximum weight for spare wheel mounted bike carrier |
Ritson Member Since: 11 Apr 2021 Location: France Posts: 202 ![]() ![]() |
Does anybody know what the maximum weight is that can be loaded onto the spare wheel? I'm thinking of buying 2 E-bikes which would weigh about 60kg (including the spare wheel mounted bike carrier) and would like to confirm if this is possible.
Cheers Current: MY22 P400e SE Prior: Discovery Sport HSE, Jaguar F-Type S, Discovery 3, RR Vogue |
Hi Mark
Thanks for your advice, you've raised some good points I would never have thought of. I already have the carrier which I previously used for standard mountain bikes, just wondering if I could re-use it for electric mountain bikes. If I get e-bikes they will likely be hard tail so I'm guessing my existing carrier would be ok for just one bike. Can you get tow bar mounted racks that will take into consideration clearance for the spare wheel and still take 2 bikes? Current: MY22 P400e SE Prior: Discovery Sport HSE, Jaguar F-Type S, Discovery 3, RR Vogue |
this is the carrier I have
![]() Click image to enlarge Current: MY22 P400e SE Prior: Discovery Sport HSE, Jaguar F-Type S, Discovery 3, RR Vogue |
MiltonMan Member Since: 07 Mar 2024 Location: Brisbane Posts: 29 ![]() ![]() |
I use this mount for my 2 e-bikes:
https://isi-carriers.com/ It is excellent, they know Defenders well & will recommend the right gear. ![]() Click image to enlarge ![]() Click image to enlarge |
Thanks, will see if there is a supplier in France or UK Current: MY22 P400e SE
Navkol Member Since: 16 Mar 2025 Location: 3City Posts: 5 ![]() ![]() |
There is a difference between STATIC and DYNAMIC loads.
The same concept applies for roof loads, where most vehicles are certified for approx 70 kg of dynamic load but people (like myself ![]() I have installed the spare wheel steps and have successfully climbed (approx 90 kg ![]() ![]() And for the DYNAMIC load (underway) ... 50 kg additional weight is tested to be OK ![]() ![]() Click image to enlarge |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3504 ![]() ![]() |
The Australian one linked to above looks perfect for my needs, l went on the website to order one but there was no option to ship outside of Australia.
Also l didn't understand the different mounting options, surely if it's on the towball there's only one type of mounting but it offers several. Anyhow l have emailed them. ![]() Click image to enlarge ![]() Click image to enlarge |
