Home > Modifications & Maintenance (L663) > Maximum weight for spare wheel mounted bike carrier
Ritson
France
Does anybody know what the maximum weight is that can be loaded onto the spare wheel? I'm thinking of buying 2 E-bikes which would weigh about 60kg (including the spare wheel mounted bike carrier) and would like to confirm if this is possible.
Cheers Current: MY22 P400e SE
Prior: Discovery Sport HSE, Jaguar F-Type S, Discovery 3, RR Vogue
Post #1069191 6th Jun 2025 10:34am
markb110
Hi
I would not hang e-bikes on a spare wheel carrier
If they are full suspension bikes the shock mounts are different from bike to bike so will hang at funky angles.
A road / gravel e bike will hang more level, assuming that they have a level top tube, any angle and again they will hang lopsided.
Next, whether emtb or gravel / road, if it has a carbon frame you are putting stresses where you shouldn’t and that could be dangerous to you when riding. Assuming the carrier that you are thinking off is the two prong style that hangs the frame.
The wheels on carrier will also be rated to carry heavier weights, some of the aluminium full power emtbs can weigh up to 25kg, which also leads to another consideration, lifting it up as high as the spare wheel.
A ‘wheels on carrier’ on the towbar is the best.
They also double up as a work stand if you need to do any last minute fettling.
I am sure that someone here will know the answer to that actual question you have asked, but it’s worth those considerations that I have added above especially if you have other bikes and or change bikes every few years that have different frame / suspension layouts.
Good luck
Post #1069196 6th Jun 2025 1:18pm
Ritson
France
Hi Mark
Thanks for your advice, you've raised some good points I would never have thought of. I already have the carrier which I previously used for standard mountain bikes, just wondering if I could re-use it for electric mountain bikes. If I get e-bikes they will likely be hard tail so I'm guessing my existing carrier would be ok for just one bike.
Can you get tow bar mounted racks that will take into consideration clearance for the spare wheel and still take 2 bikes? Current: MY22 P400e SE
Post #1069198 6th Jun 2025 1:50pm
Ritson
France
this is the carrier I have
Post #1069199 6th Jun 2025 1:55pm
MiltonMan
Australia
I use this mount for my 2 e-bikes:
https://isi-carriers.com/
It is excellent, they know Defenders well & will recommend the right gear.
Post #1069224 7th Jun 2025 3:38am
Ritson
France
Thanks, will see if there is a supplier in France or UK Current: MY22 P400e SE
Post #1069228 7th Jun 2025 7:21am
Navkol
Poland
There is a difference between STATIC and DYNAMIC loads.
The same concept applies for roof loads, where most vehicles are certified for approx 70 kg of dynamic load but people (like myself Cool ) are enjoying outdoor activities and family vacations, sleeping in the roof tent.
I have installed the spare wheel steps and have successfully climbed (approx 90 kg Laughing ) on my roof (STATIC load as I was NOT jumping on them).
And for the DYNAMIC load (underway) ... 50 kg additional weight is tested to be OK Thumbs Up (see mine setup of 2 x 20 l water cans).
Post #1071752 19th Jul 2025 8:56pm
lightning
The Australian one linked to above looks perfect for my needs, l went on the website to order one but there was no option to ship outside of Australia.
Also l didn't understand the different mounting options, surely if it's on the towball there's only one type of mounting but it offers several.
Anyhow l have emailed them.
Post #1071807 20th Jul 2025 3:59pm
